michelin PSS wobble?
Received 2,276 Likes
C4 of Year Winner (performance mods) 2019
Just took my Cup wheels and PS2s off and put on GS wheels with GY F1s, wobble gone.
I have the MMSS on my z as well. I went with the 245/35R19 in the rear. With max PSI I haven't noticed much wobble. As I lover the PSI in an attempt to gain low-speed straight-line traction I notice and increase in the wobble as well. I only get The wobble when doing WOT runs. Start at the shift 2/3 or 3/4th. With Psi at 25lbs it is really bad. I will try a max PSI run and see how they are.
Don't forget these are non-run flats and have a much softer side wall to give you a quieter better ride baby require running them a tire pressure to retain the sidewall stability. I mounted my own tires and they are supersoft sidewalls. I have use these tires for autocross and road course. I am extremely impressed with their dry traction and ride over the runflat crap tires. We have to remember that we cannot expect these tires to do drag radial duty and most likely will have to run the near max pressure.
Michelin warranted mine. The car just wasn't safe at WOT. I changed to Nitto invos. Wobble is gone, car is much more stable. 30psi in the tires. There is something wrong with those tires.
Tried it again yesterday at the drag strip.
28 lbs and 3rd gear was so bad I couldn't go over 100 mph.
Aired them to 40 and ran an 11.30&131mph. Several passes and no issue.
You can't run them low. Buy a drag radial if you want traction.
Called their customer service, got an incident number. Then local discount tire inspected the tires and brokered a 75% warranty. Not a perfect deal but at least the car is stable at WOT, and I'm not playing with air pressure.
I just happened to notice you have a base model and you went with 305 size tires...
are you on the STOCK rims?
I had my RE11s do a nice wobble when getting up above legal speeds. Tire was a poor fit for the rim. Went with appropriately wider rims and bam it's gone. The new tire may not do it because not all 305 sized tires are the same size.
Food for thought...
Food for thought...
I ran 305 R888's on stock narrow body rims for quite a while. No issues at triple digit speeds and hard (640rwhp) acceleration. Those were my track tires. I ran 305 Invos's on the same size rims. No issues with them either...but, also no traction. They were pretty worthless in gears 1 through 3. The 888's usually hooked all of second.
#33
Food for thought...
Food for thought...
#34
#36
I am starting to catalog this issue and saving links to threads...THIS IS NOT JUST A CORVETTE ISSUE! I have found threads on GT500 and even BMW forums with just a little research. Michelin was kind enough to swap my rears out for $96 (sarcasm implied) and I still have the issue.
I posted the following to another thread today:
I have been following threads like this on multiple forums (it's not just a Corvette problem) and the issue is ALWAYS the same and ALWAYS related to Michelin tires! 100% of the time after reading through a typical thread eventually it comes out the owner with the "wobble" has Michelin's. To be clear not all owners with Michelins experience this.
Me: (702whp 2010 GS) I have been fighting this and I have two other sets of rims (drag pack and DR's on spare 19" rears)...with these other rears there is NO WOBBLE! Switch back to the Michelin PSS and under hard 3rd and 4th accel the rear end wobbles and it is VERY scary!
Michelin "exchanged" my rears and denied ever hearing of this problem (despite others reporting the issue and a friend reporting the issue directly to a race engineer at COTA). And yes I have another friend locally with his 675whp GS experiencing the EXACT same issue on his low mileage car.
BTW, I was charged $96 to exchange the rears for another set.
What really sucks is I love the wet/dry traction (lateral and straight line) but cannot trust these at high speeds as under accel the car "at times" will wag it's tail like a dog with a bone!!!!!!!!!!!
Going back to Discount this week to work on exchanging for another brand.
#37
#38
Michelin took the second set back 100% and Discount covered me for the fronts.
I chose Bridgestone RE11's in stock sizing (only way) and they are solid and stable with multiple pulls.
Then I bought some of the new MT Street SS (also 325/30/19) to replace my worn NTO5r's. Took those to WannaGOFAST and busted off a couple 170mph passes clean and straight no wobble.
NOTE: had a fellow c6 driver at the 1/2 mile event complain of handling/traction. "yeah, yeah everybody is struggling with the dusty runway" I told him. Then he tells me he's having problems in third and even fourth and describes the now familiar Michelin death wobble. Without being near his car I asked if he was running Michelin (already knew)...YEP, sure enough!
MICHELIN HAS A SERIOUS ISSUE THAT'S GOING TO KILL SOMEONE!
#39
#40
I haven't tried the the R888 though I see it recommended quite a bit. I have a drag pack and an extra set of rear factory GS rims with DR's (currently the new MT Street SS) so the RE11's are my "touring" or road trip tire. Not thinking the R888's would suit that purpose.
Here is a vid of how well the RE11's work for me (of course this Mexico test was just last week and they are brand new!)
