C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
michelin PSS wobble?
Old Sep 28, 2015 | 11:29 PM
JRS 94's Avatar
JRS 94
Default michelin PSS wobble?
2008 base automatic with ECS kit at 540 rwhp.
With my new PSS tires I have a a severe side to side "wobble" over 100mph. Tires are at 30psi. 305/30/19's. Could it be breaking traction? Is there any improvement options for the base suspension? Anyone else have this issue? I don't remember the original runflats doing this.
Thanks.
Old Sep 28, 2015 | 11:42 PM
petsur's Avatar
petsur
Run PSS's and was coming into turn 1 At PMP last weekend @135 mph with no issues.
Old Sep 29, 2015 | 01:36 AM
reactor2's Avatar
reactor2
Thanks.
I seriously doubt you're breaking traction at 100mph with "only" 540whp. I've got more than that and my old 345 35 18 PS hold traction pretty well at 30 psi (above 50mph). My guess is that you have a balance problem. Is the wobble in the seat or the steering wheel? Steering wheel is usually the front and the seat is usually the rear.
Old Sep 29, 2015 | 03:30 AM
fe9_fe9's Avatar
fe9_fe9
Might be balancing! If not, you might want to check that your wheels are fine.
Old Sep 29, 2015 | 07:12 AM
old motorhead's Avatar
old motorhead
Check the ZR1 in the vid below at about the 35 second mark. Is this what yours is doing? My GS was doing that same thing right after the 3/4 shift. 345/30 19's Pilot Sport SS's. Just did it when accelerating hard. It was worse at lower rear air pressures. At 34psi and up, no wobble. At cruise or light acceleration, it didn't do it even at lower air pressures. Just did it when running hard and using all 660+rwhp.
I don't really see a down side to running a little higher air pressures. Still a good ride. The alternative for me was getting new rear tires. I'm going to scrub some more rubber off of these before getting anything different.
Old Sep 29, 2015 | 10:16 AM
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
Have the same issue with my ZR1 size PS2s. Have tried alignment and higher air pressure, neither have made any difference. Mine isn't severe, so it has been more of an irritation than a major concern, but a friend with a blown GS running new PSS 345/30R19s had severe wobble that I observed while behind him. This isn't the first thread I've seen on the issue, and the only tire brand that people seem to have the issue with is Michelin, which is why I most likely will not go with them again. They are a great tire, but when I asked two Michelin tech/reps at the Corvette corral tent at the Tudor race in Austin, they said they had not heard anything about it and were not aware of anyone having behavior like I was describing.
Old Sep 29, 2015 | 10:30 AM
old motorhead
They've heard about it. Hell, I told a rep about it. As much as I like everything else about the tire, I won't be buying them again either. Mine was on a 6K mile 2013 Grand Sport with a fresh alignment. It was bad enough at lower tire pressures that there was NO thought of trying to drive through it.
Old Sep 29, 2015 | 11:29 AM
racerxrick's Avatar
racerxrick
Thanks.
perform a search and you will find this over and over again, ALWAYS and ONLY on Michelin's and only under high speed acceleration, feels like a gyro effect and is scary as hell!
https://www.youtube.com/watch?v=G6su...EA8204FD8&t=8s
interesting vid and yeah looked about like that...I do see an adverse effect running higher psi though, mainly reduced low end grip under power!
Evan and I are both well aware of the problems each of us have had with the Michelin's, he saw my car sway bad under power at the top of third into fourth (700whp so that is some speed).
I thought these tires were the best thing since sliced bread and now I don't trust them!
NOTE: I did find that one rim had pitched the wheel weights (2.25oz) though that shouldnt cause a sway. I aired them up and the car seemed OK but now my low end grip is shot.
yes and AMEN!
Old Sep 29, 2015 | 12:59 PM
JRS 94's Avatar
JRS 94
Yes that is exactly what mine does at 30psi, I'll go up to 34psi and give it a try, Thanks
Old Sep 29, 2015 | 04:21 PM
bdickey058's Avatar
bdickey058
Had the same problem with my pss. I brought it to a tire shop and the tire was bad. I guess there was a bad batch or 2 that got released to the plant. Michelin will discount you a new tire depending on tread depth. I bought a different set of pss and my car stays stuck. i'm at 747rwhp and that wobble was crazy scary. Always kicked in on my 2 to 3rd shift. Take it to a tire shop and have them check the balance. Lots of info on this matter that Michelin keeps on saying they have never heard anything about which is bogus.
Old Oct 2, 2015 | 06:37 PM
GeneSch's Avatar
GeneSch
I get this with 24lbs doing 40-140 rolls. From 3rd to 4th shift it chimes a little. didn't have an issue at 32lbs but then I get zero traction at 40mph...
Do you know the date codes that they were concerned with?
Old Oct 3, 2015 | 12:09 PM
JRS 94's Avatar
JRS 94
Update, Called Michelin and was told to go to local discount tire for them to look at my tires. Michelin has warranted my rear tires at 75% and fronts at 55%. Hate to give up on these but apparently they must know there is a problem. Going to try Nitto INVO's next. Any experience with INVO's or any reason NOT to go with them?
Old Oct 3, 2015 | 12:18 PM
EvanZR1's Avatar
EvanZR1
Seriously doubt it's a date code issue, I've seen the same issue on PS2s, Cup 2s, and PSSs (not all mine) spread across at least 3 years.
Old Oct 3, 2015 | 04:39 PM
magls2's Avatar
magls2
Is this a Michelin tire issue?
Are there any other manufacturers with similar issues
Old Oct 3, 2015 | 05:00 PM
old motorhead
Last I checked Michelin was a pretty well respected tire manufacturer. How'd they manage such a total cluster phuque on this size?
Old Oct 3, 2015 | 05:59 PM
JRS 94's Avatar
JRS 94
Anyone using Nitto INVO's? I do not want to make another mistake. thanks
Old Oct 3, 2015 | 06:12 PM
Streetk14's Avatar
Streetk14
Sorry, I don't. But I don't think of Nitto very highly when it comes to performance tires. Drag radials maybe, but not Invos.
As a second choice to PSS, I'd try the Bridgestone RE-11. They're stickier than the PSS and have pretty good life. The only downside is that they tend to flat spot very quickly. So you can get a shimmy as they warm up. I'd grab a set of those before the Nittos, but that's just me.
To michelin PSS wobble?
Old Oct 3, 2015 | 07:01 PM
old motorhead
Yup, agree on all of that. I'd do Invos on the front end for mileage and handling only. They're pretty much useless on the rears if you're trying to get any sort of traction. MT has some new stuff with soft tread and stiff sidewalls. Might be something to consider.
Old Oct 3, 2015 | 08:29 PM
EvanZR1's Avatar
EvanZR1
I've only heard of this issue affecting Michelins, specifically PS2, Pilot Super Sport, and Sport Cup 2s.
The new MT Street S/S look like they should be good, but they keep backing up the release date. They've been due out for over 6 months and still nothing.
Old Oct 11, 2015 | 10:40 PM
JRS 94's Avatar
JRS 94
Michelin PSS off, Nittos on. Wobble gone. Strange, would love to understand this.
