C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
6L80 to 4L60 tune needed
Old 05-03-2015, 07:25 AM
ironhorse583
ironhorse583's Avatar
Default 6L80 to 4L60 tune needed
I spent last winter installing a 4L60 into my 07 in place of the 6L80 and now i need a tune to finish it off. Can any1 help me out with this.? From what I have read all i need is 6 speed tune but im not sure how to turn my tune into one. I have an HPT file...who can help me out with this????
Old 05-04-2015, 07:52 AM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
Not that simple. The TCM that controls the 6L80 wont work on a 4L60. You need a transmission controller to do that.
Old 05-04-2015, 12:40 PM
ironhorse583
I am using the PCS TCM-2000 to control the trans. i believe all i need to do is flash a 6 speed manual file to the car so its not looking for the 6L80..correct me if im wrong..
Old 06-08-2020, 10:20 PM
slarsen47
Cruising
slarsen47's Avatar
Just off topic but why did you replace the supposedly superior 6L80 with a 4L60?
The reason I ask the question is because I am looking to buy an auto C6 and don't know whether to get the 4 or 6 speed.
Old 06-09-2020, 07:02 PM
ironhorse583
The car was making just under 800 rwhp and I could not keep a trans together. It was built with the best parts available at the time and tuned by the transmission builder.
Old 06-10-2020, 01:01 PM
romandian
romandian's Avatar
so the 4 speed is stronger than the 6 speed? really?
Old 06-10-2020, 01:21 PM
ironhorse583
Back then with the proper tuning the clutches would not survive in a built 6L80. The RPM built 4L60 was and still is a beast and will take a beating.
Old 06-10-2020, 01:22 PM
ironhorse583
Oops
Old 06-11-2020, 11:19 AM
irok
irok's Avatar
I think the 4L65E is stronger.Have 1 built by RPM for mine and friend is on his 6th 6L80 and as we speak his is slipping in 4th,5th and 6th.
Old 06-11-2020, 12:31 PM
slarsen47
Cruising
slarsen47's Avatar
is it a good strategy to program 3-4 shift so it will not go into overdrive at more than 75% throttle position.
Old 06-12-2020, 06:36 AM
irok
irok's Avatar
At 155 mph on the dyno with a 3:42 gear and a 28" tall tire mine still has a lot of rpm left in it before it would need to go into overdrive.Definitely don't want it to go into overdrive on a 1/4 mile pass
To 6L80 to 4L60 tune needed
Quick Reply: 6L80 to 4L60 tune needed
