MAF Table - 2006 Z06
I changed cold air intakes and I now have the Halltech MF103 which says it uses the stock tables/settings. Does anyone have the stock tables for the C6 Z06 they can send me or whatever is needed to give to the tuner to install. The tuner would use HP tuners but I would need table in excel and then import or type in. I am not sure what else I need and I will probably need some more adjustments but this at least gets me in the ball park to start. I presume it is the table that has the hertz readings on one side and the grams per second on the other?
If your tuner can't dial in a maf, or doesn't have access to stock tunes, find a new tuner.
Stock maf tables can be used, and for a CAI of any brand they only get tweaked slightly. Just let him dial them in as any tuner should. Stock values are available in the HP tuners database on their site.
double06 (08-07-2016)
OK Good
I was just trying to save a step, but if they have them easily available at HP then it should not be an issue.
