So what do u guys thing the BEST Intake/Heads Combo is???
Old 06-08-2007, 01:18 PM
supercoolsix
supercoolsix's Avatar
Default So what do u guys thing the BEST Intake/Heads Combo is???
1. L76/L92 Combo?
2. Fast/Stock combo?
3. Ported Stock/Ported Stock?
4. _______ / ________ <--- your input
The limit is $4K'ish... so what do you think?? I've searched around but haven't been able to put the hammer down on what is the best combo right now for around $4K'ish
thanks for your input..
Old 06-08-2007, 01:29 PM
glennhl
glennhl's Avatar
I like Tom Wong's setup he's used several times. Stage 2.5 heads from Texas Speed and a mild cam (I think it's the Lingenfelter GT11) along with a ported stock intake. He's made very good power with this docile setup.
Old 06-08-2007, 01:44 PM
cmb13
cmb13's Avatar
It would depend on your goals, I'd suppose.
Old 06-08-2007, 02:07 PM
JFTaylor
Support Corvetteforum!
JFTaylor's Avatar
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I'll let you know when CARTEK finishes my 2X package I've researched just that for the past month and my head is swimming.
Too much Cam is not always a good thing. Like me, you probably think that "Bigger is Better", its not. With the Cam and the Heads, in certain applications, 205cc runners will out perform 225cc runners. And a 232/240 cam could be outdone by a 222/226 - go figure. For NA applications, smaller is generally better.
It's best to get with a good tuner and ask questions.
OK Guys Flame away.
Old 06-08-2007, 02:36 PM
supercoolsix
thanks for your input fellas!
much much appreciated!
Old 06-08-2007, 02:50 PM
LS1LT1
LS1LT1's Avatar
OK Guys Flame away.
No flames needed. 100%
The factory 243/LS6/LS2 cylinder heads are still amazing pieces to work with, they have the ability to make crazy power and more importantly awesome performance out on the track and the street. If I were going with a naturally aspirated, stock cubic inch combination on an LS2 (or LS6/LS1) it would be Cartek ported heads with a FAST 90mm intake set up along with the appropriate Cartek custom grind cam choice to compliment both.
Proven track results/performance while still maintaining near stock level daily drivable performance is hard to beat.
Old 06-08-2007, 03:16 PM
andreas g.
andreas g.'s Avatar
You're looking for a head /intake combo right? Without a cam why bother. Your performance gains will be minimal. If you're not changing cams then your stock components are fine. Just put a set of headers on and be done with it.
Old 06-08-2007, 03:26 PM
HITMAN99
HITMAN99's Avatar
Stock is best. No installation hassles, zero cost, doesn't affect resale value, no problems with warranty, emissions, or gas mileage.
Next best would be a ported intake, combined with LT headers, CAI, and a good tune. That's what I'm running.
Old 06-08-2007, 03:53 PM
supercoolsix
of course i'm going to throw in a cam, but i just wanted to know if there is a combo that some of you guys heard of/experienced... a intake/heads combo that went great...
i'm also gonna throw in a stealthy cam... =)
Old 06-08-2007, 06:39 PM
andyandy98
andyandy98's Avatar
Are "Cartek Ported Heads" using stock and modifying them? Or are you saying these Cartek heads will be completely different from the stocks?
Old 06-08-2007, 07:39 PM
LS1LT1
LS1LT1's Avatar
Yes, they either use your factory stock heads or take your stock heads in as a core and give you a set that's already been professionally cleaned, checked, painstakingly hand ported and then reassembled using the best valvetrain (springs, retainers etc.) components available etc.
As mentioned earlier the standard heads on the C5 Z06s and the LS2s are phenomenal castings to start with on a heads and cam (or even a stroker) package.
Old 06-08-2007, 10:15 PM
SpinMonster
SpinMonster's Avatar
Cartek 4x heads have been used on a stock bottom end and resulted in faster than 130 trap speeds without silly-sized cams. You get what you pay for and at under 2k for the heads, they are worth it. I've seen higher dyno numbers from tuner favorite heads that havent gone faster.
Old 06-08-2007, 10:48 PM
k0bun
k0bun's Avatar
Location: NJ..."the way I saw it, everyone takes a beating sometimes."
Damnit Spin. I'm fighting myself not to get them yet.
Old 06-08-2007, 11:45 PM
Evilways
Evilways's Avatar
For good performance, not nessecarily the most performance, a stock feel and appearance,along with near-stock idle and drivability, the L92/L76 is a great way to go, but a cam and tune is needed.
Old 06-09-2007, 12:31 AM
bowmanized
bowmanized's Avatar
Ported Fast by Tony Mamo/Trick Flow 215s
Old 06-09-2007, 01:10 AM
Batman7
Batman7's Avatar
Not sure what the best is as there are many tuners and individuals who have put together some very impressive packages.
I am currently having a H/C package done and going with a stock ported and the new Trick Flow LS2 castings and a Comp Cams custom grind, I think a 233/239 on a 113 LSA @ .585/.595 lift thereabouts. I'll post my results in another week to ten days to share with all. I am working with an excellent tuner and shop so I am expecting good things.
Old 06-09-2007, 02:37 AM
12oh
12oh's Avatar
afr205's/fast/224-228cam is a proven combo that makes power.
i'm going with the same pkg, but opted for thunder racing's cheaTR cam(215/230 629''/592'' 117lsa) for use with stock a6 converter. if i had a
m6 the g5x3 would have been my choice.
but from what i here CARTEK's stg 3x pkg is the ****.
To So what do u guys thing the BEST Intake/Heads Combo is???
Old 06-09-2007, 08:29 AM
vettecop1125
vettecop1125's Avatar
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
I have the L92/L76 setup with a very mild cam and I'm very satisfied with the results - 460/432.
Old 06-09-2007, 09:21 AM
Craigster05
Craigster05's Avatar
St. Jude Donor '07-'08-'09-'11-'12
Great advice.
JFTaylor, your doing it right....Great to see. Ive always felt that guys who thought out exactly what they want before they start modding are the happiest in the end. Too many guys get frustrated when they try and hit an HP number, mod the heck out of the car, and then they cant stand driving it because it changed too radically.
Thats also why I love Corvettes. The platform is there to enjoy it as is, or turn it into anything you want, and no matter what you do, it's a blast to own and we have great enthusiast community to share it with.
Old 06-09-2007, 06:00 PM
JFTaylor
JFTaylor's Avatar
St. Jude Donor '06
Welcome to the Dark Side. . . . .
Quick Reply: So what do u guys thing the BEST Intake/Heads Combo is???
