Cutting shroud for VaraRam SC CAI Install on 06 C6
Cruising
Does anyone have a copy or PDF of the shroud cut out pattern for the VaraRam SC CAI? I bought a used CAI here on forum. I've read several articles on the installation and not interested in buying the precut shroud. Any advise/help on cutting shroud is appreciated.
I also bought a Vararam SC. Sorry but I did not save the template for the shroud cut out. I found that the template was only an approximation of the hole required. I had to trim the shroud a dozen times before the intake shroud fit. Make sure you use a sharp utility blade with minimal depth to prevent gouging anything under the shroud. I am happy with the outcome despite the time it took to do the install.
The template is ONLY a rought starting point. I trimmed mine 3 or 4 times to get a good fit. So you may be better off to cut an undersized hole and then trim til you get the fit you want. Take your time and PROTECT the condenser with thin plywood, plexiglass, old license plate etc while you cut. A lot of guys brag about how fast they install stuff. Don't do that.
Go to Harbor Freight and buy a vibration cutter for $20, you can cut the shroud like butter and don't need to worry about accidently cutting yourself or something under the shroud. It will serve as a handy tool around the house for many other projects anyway. I think you can call Steve at Vararam and he will mail you a template if you want one, he is a good guy and very customer service oriented.
If you would like a picture of the cutter I would be happy to PM you the details as well. I have installed 2 Vararam systems with this cutter and man does it make cutting and trimming the shroud a breeze!
Another trick is to pull the inside piece out and away as your cutting. It's alot closer to the condensor at the top than the bottom so be careful! But once you have it out, you can see that it was still about an inch away at the top. So it's very important to only have your "very sharp" razor knife's blade about 1/8" - 1/4" out . . . NO MORE!!! It actually take Patrick at Vararam about 4 minutes or so to cut one out safely. But he is use to it. BTW, call Steve at VR and he'll be glad to send you a new template.
I actually went so far as to pull the shroud out on mine so I could do a nice job of cutting. Wow, what a major PITA that was! Then, like a post above mentioned, after I re-installad it, which was also a major PITA, I still had to do some trimming! So, I don't recommend doing that....
i bought the precut shroud so i didnt have to mess around with the cutting. so, instead i had to mess around with removing and installing the cover(but at least i have the original if i want to remove the vararam in the future)
I don't have the template any longer, it went with the intake when I sold it. However if you place the template like shown in this pic you shouldn't have to trim anything. Make sure the dotted line is in the crease. VR's instructions are crap but Steve and Patrick from VR showed me exactly how to place it when I bought the VR at Carlisle. As mentioned above be EXTREMELY careful when cutting the shroud. Hope this helps.
Chuck Cow installed mine (think he's done a few in his time?), but I watched him. Placed the template, traced it with a Sharpie, and cut it out in about 15 minutes - no trimming required.
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Thank you....
Thank you. For any of you who have seen our Vararam installs, they are second to none.
The template is misleading and over the years we have modified our own template....
We always keep the part of the shroud we remove and Dan modifies it on the bench to make a perfect drop-in.
We loan our templates out to those that buy the Vararam from us so that there are no sloppy installs out there
with our customers....
It's not hard, but unfortunately most people never get it right.
Our templates make it much easier with no guesswork.
Chuck CoW
Chuck CoW
Chuck CoW
Chuck CoW
Chuck CoW
Are precut shroud still available? If so, how do we go about buying one? Are they foolproof with everything lining up and fitting?
Thanks,
WBE
Atlanta
Former Vendor
What we do here.....
When we sell Vararam C6 units to customers, we always separately mail out a template
made from the removed portion of a previous job. This way there is no mistake.
Do not try to cut the shroud with a blade.... We use a modified mini air saw.... Too fast a cutting speed melts the
shroud right behind where you cut so slightly turning down the speed is the best idea.
Call me if you need help.
Chuck CoW
https://www.corvetteforum.com/forums...ched-here.html
Thanks,Matt
Vararam Support and Install
As noted get the template. A Corvette owner I know just had a used one installed by a local shop. They butchered the job!
I have one on my 2011 and it was installed by ECS at Carlise and done right.
I recently had a call into Steve at Vararam regarding my foam seal around the filter inside the box. He was great and had one sent out to me without charge and it was delivered in a few days. Great Customer Service.
Jim B.
Jim B.
