tps and drag racing
tps and drag racing
If i change to drag radials at the track and have my other wheels with the sensors at the track and come back near them after each pass will i have any problems regarding sensors?
Received 2,061 Likes
The only time I had the computer talk back to me, was nearly 20 miles after leaving the track. I had my street tires in the trunk too. I'm guessing the TPSM has to be a lot closer to the normal location for the sensors to communicate.
I also suspect the computer retains the last information received, rather than default to zero pressure. Several friends always drive 20-30 miles to the track on drag radials and have never mentioned it caused them problems.
no problems. i drive my car to the track and at the track with no tpms and my car runs just fine. yes the light comes on saying check it but i ignore it all the time. it never affects my performance. when i get home i put my stock wheels on and my computer fixes itself in a few miles and the warning goes away.
I believe that someone on the forum posted that if one would put a tpm in a 4 inch pvc pipe with ends and put 30 lb of air pressue in the pvc pipe and place the pvc pipe in the back, the dic would read off that tpm and no code would occur. I am going to try that soon. Hopefully it will work.
St. Jude Donor '08-'09-'10
Pipe about 5" long. Drill & tap a shrader valve in one end and A TPS sensor in the other end . Then Scan it in and your set for 30#. A nice trick. As we all know if yout Car senses Low tire pressure less than 25psi tpms triggers and torque management comes in. I also heard if you dont turn the traction control off it will introduce torque management.
