What is the stock rear gearing on my 05 C6 A4
What is the stock rear gearing on my 05 C6 A4 convertible. It has the mag ride. F55 I believe. Looking at rear end gear change.
THANKS RAYZZZ MY CORVETTE LIKES MY MONEY
Also how much will I need to pay to get a rear end set up with 3:90 gears. Who should I purchase one from.
stock
Is there a rear diff out of a vette that has lower gearing that I can just swap in to my car.
http://mysite.verizon.net/foofoo2/c6/A4-3.73.html
I did the whole rear end: 3.73 gears, 2800 stall converter (flash to 3600), FLT Stage5 A4 trans w/ cooler.
Your local Corvette motorsports shop should be able to fix you up
That is likely the gears he has unless the car was originally ordered with the axle ratio option then it would have the 3.15s (which was also the gears included on automatic Z51 cars), this info applies to 2005 cars only of course.
Only way to know for sure is to either look at the build code sheet or the rear differential itself.
Good Luck
The easiest way to find out what rear end ratio you have is to look up the RPO codes located inside your glove box. Look for one of these two codes: GU4 = 2.73 rear ratio, G90 = 3.15 rear ratio. I had 3.73's installed in my 05 A4 and they are awesome. Cost me about 1500.00 to have the job done.
Good Luck
Good Luck
