Old 03-06-2015, 01:44 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension How-Tos
Print Wikipost
Suggestions for base C6 suspension upgrades
Old 11-01-2010, 07:03 AM
Joe C
Joe C's Avatar
Originally Posted by Leprkon
A thicker tunnel plate and set of improved sway bar end links will make a big difference, as well. Much stiffer chassis.
speaking of tunnel plates, is there any difference between the base, Z51, GS, Z06, or ZR1 tunnel plates? i'm thinking thickness here...
Old 11-01-2010, 10:09 AM
Boomer111
Boomer111's Avatar
Just taking a wild guess here and am saying no. I think we would of heard of it as a mod if it was available. I went with Elite Engineering's plate with heat shield.
I very will could be corrected here....
Old 11-20-2010, 02:48 AM
FIREC6
FIREC6's Avatar
A little info here?..08 C6, bought it with a supercharger and lower profile tires...as a result the front end sits REALLY low. Any easy crank methods to raise the front end up about an inch? Due to the front tire pivot position, lowering the back might help also...any ideas??? Thanks.
Old 11-20-2010, 09:29 AM
Boomer111
Boomer111's Avatar
The C6 has adjustment height screws at all four corners. Easily able to lift the front end back to stock height. Do a search on lowering and just turn the screw the opposite direction.
Old 11-20-2010, 10:45 AM
timd38
timd38's Avatar
I did all the economy stuff and then finally said screw it and bought a Pfadt suspension kit. Wait until you can do it right instead of doing it twice. It will save you both time and money.
It rides better with the Pfadt kit than it did with the Bilsteins and aftermarket bars, plus te pFadt stuff just looks great.
Old 11-21-2010, 11:27 PM
studiovette
studiovette's Avatar
Originally Posted by CMY SIX
best $500 you can spend on a base model! bilstein sports and Z51 sway bars! don't care what the arm chair engineers say!
Originally Posted by bluekey28
A great place to start. Put your C6 through it's paces & decide if you like the results and then get rid of the GY run flats. You'll have a different/better performing vehicle.
Originally Posted by FloydSummerOf68
Shocks, Swaybars and Tires...your car will be completely new to you.
Originally Posted by Boomer111
I went with the Koni FSD shocks and the Z51 bars and got rid of the runflats for my Base 08. Greatly improved the ride and noise. I felt the front end of the Base was a little to bouncy for me, the FSD's did the trick. You could save some $$ by going with Bilstein shocks, other Forum have given them good reviews too. The FSD's are around $700 while the Bilstein are $300. Do a search of the design of both and decide.
Good luck.
I have an 07 F55 option . Will I also benefit from these upgrades? Z51 bars Bilstein shocks and the tires obviously are a no brainer
Old 08-06-2014, 07:14 PM
slingct3lt
slingct3lt's Avatar
Originally Posted by Gene Culley
Thanks for the referral. The C6 Z51 sway bars with the 2010 Z06 shocks are our best selling combination!
Gene please PM me the prices for this setup shown above ^^
Old 08-06-2014, 09:47 PM
TorontoC6
TorontoC6's Avatar
Get the LG G1 bars with the quiet end links, and some Bilstein HD shocks (group buy). The LG rear bar is adjustable - run the rear at it's softest.
You also want to find some Z51 or Z06 springs as well - look for some used. You will save money and they don't wear out.
Get a good wheel alignment.
Old 08-07-2014, 07:11 AM
el es tu
el es tu's Avatar
Originally Posted by mbracer
I have had my 07 case c6 for about a ear and am looking to do some mild suspension upgrades to improve handling but I dont want to lose the drivabilty (no lowering or buckboard type ride), anybody who has done this please tell me your thoughts and suggestions, thanks.
z06 front spring, keep the base rear spring
zr1 front sway bar, then a z06 or z51 rear sway bar
z06 shocks or bilstein
Old 08-07-2014, 01:51 PM
ptroxx
ptroxx's Avatar
Location: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
What about some Z06 sways and shocks ? how would this be for a base >
Old 08-07-2014, 04:47 PM
el es tu
el es tu's Avatar
the bias is more toward oversteer with the full z06 swaybar setup. Mixing the Zr1 front and z06 rear (or z51 rear) gets a bit more balance, however, its all about your driving style and also how the rest of the suspension is set up.
relative sway bar rates:
Old 10-29-2014, 12:09 PM
slingct3lt
slingct3lt's Avatar
Gene could you PM me a price and availability on this setup for my 2012 C6 ?
Old 10-29-2014, 12:36 PM
  #33
JAvery20
JAvery20's Avatar
I believe Gene is currently unable to fulfill orders, fyi.
Old 10-29-2014, 12:41 PM
  #34
slingct3lt
slingct3lt's Avatar
know of anywhere else I can get a similar setup? I found the sways on WCC for not too bad brand new (oem GM). I cannot find the springs though..... Any help would be appreciated.
Old 10-29-2014, 02:14 PM
  #35
JAvery20
JAvery20's Avatar
We can't really link on here to non CF sponsored sites/vendors, but try google. I just checked and found some in about 20 seconds.
I am looking for a set of the z51 sways as well. On the fence about the shocks, but bilstein seems like a nice option.
Old 10-30-2014, 05:28 PM
  #36
C U IN REARVEIW
C U IN REARVEIW's Avatar
I agree. I did tires, then zo6 shocks, then Z06 swaybars. ....then phadt featherlights coilovers and Johnny o Connell swaybars. .......then, HOLY CRAP DOES THAT CAR HANDLE now!!! save your money and do it right the first time.stock suspension sucks unless you want a powerful car with fluffy/luxury ride and dont care about handling. ....
Old 10-30-2014, 09:36 PM
  #37
Stwigg5
Stwigg5's Avatar
Z06 shocks and z51 sways that's what I did to my base 07 and I still can't believe the difference in how much flatter the car stays in a turn once you do that you will notice how much body roll the base suspension actually allows
To Suggestions for base C6 suspension upgrades
Old 11-01-2014, 03:02 AM
  #38
bontrager
bontrager's Avatar
I would lower the car on stock bolts and sticky tires will also help.
I added z51 sways bars and haven't noticed much of a difference.
Old 11-01-2014, 03:51 PM
  #39
Boomer111
Boomer111's Avatar
I noticed a significant improvement when adding Z51 sways and FSD shocks. I did this together on a 1LT coupe.
I feel the sways levels the car in the corners.
The car seems to handle fairly neutral.
Old 11-03-2014, 07:38 PM
  #40
berk4422
berk4422's Avatar
I did the same to a base 3lt and kept the base springs, the car is neutral. Sometimes under steer, but slight lean towards over steer. My ride is 1.2 inch lower on stock bolts.
Quick Reply: Suggestions for base C6 suspension upgrades
