Not sure if a sensor replacement can be accomplished at home.
What would I need besides the new sensor? Is there some kind of kit of fasteners/washers/orings easily available? I have an ATEQ VT30 TPMS tool so I can reprogram the car for the new sensor.
If I deflate the tire (non-runflat Michelin PS2) completely, can I push the side in to expose the sensor or does that require a tire machine?
best to go to a tire store. They should take the nut off and let the old sensor drop into the tire. Otherwise, the bead might damage the sensor, since it sits real close to the path of the bead when it breaks from the rim. Then, I think they need to be put back the same way, except a fish wire is installed to pull the sensor back out thru the wheel hole after the tire is mounted.
IMO you will never get the bead to break without a tire machine. GY RFs are very stiff tires and seat to the rim very securely. Then you have to get it re-seat. Its not worth even trying for the $20 it takes to have it done right. My understanding is that it is very easy to damage the sensor if not done correctly.
One more thing - the new sensor will need to be re-set so it can be recognized by the computer. U need a special tool for that. You may know that already.
with the above comments - take it to your local Discount Tire.
Here's how the sensor mounts in an OE wheel:
When you get a new sensor, make sure you get the proper one for your car. If you're getting a GM OE sensor, the 2005-2009 C6 uses a gray one like you see in the pictures above. The 2010 and newer C6 uses a green one.
And,as mentioned, you'll need to have it programmed into the TPMS computer in the car.
I have an ATEQ VT30 tool, reprogramming is no problem. I just wanted to know if the mechanics of getting inside the tire to get to the sensor was doable at home. Keep in mind that I do not have runflat tires.
You can't get coffee here in Silicon Valley for $20, so I expect going to any shop to do this will get me robbed.
Well.....to break the bead, I've heard that Bubba down at the Shadetree Auto and Lawn Mower Repair shop has been known to jack up his pickup truck, lay a wheel/tire on the ground under a tire of the pickup, then lower the pickup down to break the bead of the tire that's laying on the ground.
Of course, I don't think Bubba is too concerned about the cosmetics of the Pinto and Neon wheels he's working on!!
And, if he busts his hand when the jack slips while his hand is stuck inside the tire, he's got good insurance (Medicaid) and we'll pay him unemployment and OJI welfare benefits until he's ready to work again.
So.....I say don't take it to Bubba (or do like Bubba!).
Take it to your local tire shop. Many owners have reported here on the forum that the shop has been able to replace a sensor without completely removing the tire, and if the bead is just broken and the sensor replaced without the tire being moved on the wheel, then no balancing will be required.
i was told it was possible to break the bead and swap out the sensors. btw, i use to break the beads at my dads shop using one of the arms on the lift, worked like a champ, but that was back in the day when 15" rims were HUGE!!! F these low profile tires.
I successfully replaced one on a front wheel of my C5 (with non run flat tires). However, I have a cheapy Harbor Freight tire machine that I used to break the bead loose. When the bead was loose, it was easy to push the tire in enough to replace the sensor. Nevertheless, I think it is a good idea to go to a tire shop
Turns out a friend close by has a tire machine at his shop and the valve/stem tools. I ordered discounted new Shrader sensor and service pack ($50 total) and I've got the programmer, so I'm all set.
Just got back from the shop. Yes indeed, the bead can be broken and the sensor replaced without the need for removing the tire. See my newly created thread at http://forums.corvetteforum.com/c6-t...post1578430096 for pictures and details.
Just to resurrect and old thread, I did this today using a Harbor Freight bead breaker (I use it to change tires on my motorcycle) and it was easy weasy. Went to Americas Tires and they reset the sensors in 2 minutes. It would have been shorter, but I had to prove to the guy that a magnet will not work on the C6s (though I read some early models got the old TPMS sensors). Thanks for this.
I used Dorman 974-012 sensors that are two pieces. Just match up to the old sensors, and tighten the screw. No Leaks and no low battery for now, Yay. $166 for four online.
Hopefully, the Dormans will last better for you than they have for me. I purchased 4 last year, 2 failed within two months and a third failed a couple of months ago.
House of Wheels sells the GM sensors for a competitive price so if you start having issues with your Dorman sensors give them a call.
I use my milling machine w/drill chuck to break bead on my motorcycle tire - after making the "T" shape bead breaker with 1/2" cres rod welded onto 3/16" thick x 2 3/4" round cres plate. Also a great combination for crushing soda cans.
But for car tires, I take it to tire shop and let them have my $25.
Back in the days while I was going to University of Hawaii, one of my part time job was working delivery for "Chicken Delight". The worst tipper was from the wealthy people in all the well to do neighborhood!
Lesson learned in life: For the most part, the rich gotten rich because they know how to manage their money.
What do you mean by "just match up to the old sensors"?
I did a grand sport conversion on my 06 and didn't realize at the time GM nicely changed the TPMS sensors, I thought the tires were filled with nitrogen because of the green caps, now I know not.
Any how I bought one Dorman 974-012 for now to see if it will register with my POS VT5 tool and the vette, thing is I sold the old rims so I have TPMS to test on the vette. My VT5 works on my escalade though, but I can't get it to work with the Dorman, it isn't mounted in the rim yet, but shouldn't it still work, or am I missing something here?
