close up pictures/inspection of OBX headers inside
I got my hands on a set of OBX headers and decided to take some pictures for you guys.
The order was for 1 7/8" inch primaries, 3" collector and 3" x-pipe. However, the package that was sent appears to be 1 7/8" primaries, 3" collector and 2.5" x-pipe. Communication with the vendor via email was easy, so hopefully this will be a quick/free correction.
I don't have measuring calipers but, I found the circumference of the primaries to be ~6", so this would lead me to believe the primary size is correct at 1 7/8".
The 2.5" x-pipe was the only part of the kit that I wasn't very satisfied with. It looks like they just burned through each of the pipes and welded them together. I'm not sure how other vendors do it, but compared to the nice stamped 3" 'X' peice I added to my C6Z exhaust, this is not very pretty.
The headers however appear to be very good quality. The primaries mate with the flanges very well, the pipes don't appear to be crush bent. The collector doesn't have a merge spike, but is generally clean.
The X-pipe internal crossover hole does not look to be "anywhere" as large as the crossover hole in my Chinese 3" X-pipe.
My $.02 on the OBX X-Pipe.
I would be tempted to cut a large round hole with a hole saw in the side of that x-pipe, grind the internal hole out to the weld line than weld the round plug that I just cut out back in.
The internal blend hole may not need to be that large but from the photo it looks a little on the small side to "me".
The rest of the pics of the internals from what I can see look fine.
PS: The "close ups" of the exhaust flanges show that the tubes come all the way through to the flange surface, mine did not come all the way through on the set that I bought.
The American Racing X-pipe looks good.
I'm surprised there aren't more posts in this... with all the OBX threads lately I thought one that documented the latest quality of the product could be helpful.
St. Jude Donor '11-'12-'13-'14
I wasn't aware OBX had the option of a 3" X-pipe. I talked to a couple different people and 2.5" was what they offered for the C6.
If you do indeed get a 3" x-pipe, let me know as I'd be curious to pick one up myself and do a back to back dyno comparison to see if it improves on my 494whp/443tq number.
So, if the X pipe looks to be "less than desired", what's the best option... buy a different X pipe (ebay, corsa, or other), or maybe take the OBX to a muffler shop and have them "open it up"?
I'm curious to hear if you have any luck getting a 3" x-pipe. I also thought only 2.5" was available.
Ah, that makes more sense.
I almost ordered the Z06 system but didn't want the hassle of fitting the muffler side of the 3" x-pipe to my 2.5" factory NPP. Honestly, I can't imagine it making very much of a difference and I'm very pleased with how everything turned out for my current mods.
Now--if I was going FI--that might be a whole different ballgame.
Keep us posted turbo
Very timely and thanks for posting. I plan to put these on in about a month when I'm in for the winter.
I wouldn't want to spend too much money on other parts or correcting these headers, because at $636 shipped, they're a good deal... add in the new parts and labor and it may be tempting to get a real set of kooks.
I'd also be curious to know if you could just buy the headers themselves and fabricate your own x-pipe. If the price works out, this could be a good option for guys w/ good local shops who also want some adjustments doen to run 3" mid-pipe to 2.5" mufflers or something that isn't 'bolt on'.
It definitely wasn't as 'clogged' as the pictures you show though.
Agree... Just need to find a weld shop as good as Grand Sport Man
Also agree this would be a nice option. If I can't find a set of NPP exhaust, I'll likely go with Z06 bi-mode. I was resigned to using an adapter, which isn't bad, but it would be nice to have everything 3"
Do you mind PM'ing me where you got them from? I just got a Z06 axleback for my base C6 and that system interests me at that price point. I'm also not going to tune my car so I can keep the engine warranty and spending $1700 on headers doens't make sense to me.
im sure you will have to tune if you do headers
You dont have to tune when you get headers but you will have a CEL if you delete the cats. I drove around for weeks with the OBX and no tune, and put it on the dyno for a baseline before the cam. 421whp/398tq with intake, headers, and ported TB.
I'm waiting to see what the vendor does regarding the product mistake before I recommend them or pass on their information. I'll send you a PM once it's sorted out.
