Map Lights Stay on all the time
I have a 2009 and the switchs on the mirror won't shut the mirror lights off. Is their another switch somewhere? The lights are on when ever the car is running. They time out in about 15 minutes after the car is shut off.
Lyle
Lyle
The following 2 users liked this post by Blindfingers:
C6Ninja (02-23-2024),
joraeperkins (10-24-2019)
Actually, push it in one time and release it. You won't see an immediate result, but when you get out and shut the door, the map lights will go out when the car locks.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,822 Likes
2015 C7 of the Year Finalist
To operate properly start by insuring that the two buttons on the mirror are in the off position. Off = in (on = out)
Then get out and close door. The mirror lights should dim out after 20 seconds. IF THEY DO NOT DIM OUT, push the dimmer light switch on the left side of the dash 1 time.
Then get out and close the door. The mirror lights should dim out after 20 seconds.
Elmer
Elmer
Only about 75% to 80% of C6 owners do that.
I've seen that problem posted here many, many times in the 8 years I've been on the forum. But I did it without realizing it a few months ago. My wife asked me why there were some lights on in my car.
I replaced the map and footwell lights with leds. They still dim but are barely on with the slightest of light. I would really doubt this would be enough to drain the battery. Just curious if anybody else had this issue when changing to LEDs
Received 2,093 Likes
Yes! No problem and no battery drain. Kinda annoying!
I have the opposite problem. The map lights on my mirror won't come on any more. They were working fine (with LEDs) a couple of months ago but nothing I do now gets even a glimmer out of them..
2020 C6 of the Year Finalist - Modified
Map Lights
I believe I got mine through JWM.
Elmer
Elmer
You guys are great😁
I bought the cheap Ebay set of led and have the same problem. Sometimes you get what you pay for-a problem, and end up paying again more to fix it.
After finding my mirror lights permanently on several times I put a plastic lock collar with set-screw on the dimmer button that prevents the button from being accidentally pushed in. I think I was bumping the dimmer button with stuff or elbow or knee or feet or some body part - never figured out what - but the mirror lights stay off after a short delay.
Haigmeister (02-24-2024)
Mine stay on all the time since switching to Sylvania LEDs. They are definitely "off" with the switch on the rearview mirror and I've pressed the dimmer. They are much dimmer than when they are on. I think my SS always sent power to the bulbs to be able to trip an error when the bulbs burn out. I wonder if this car is the same.
