How to Remove c6 fuse/relay box
I just knew that someone would come through...
I feel if everyone's breaks in that same spot it's a GM flaw somehow and they need to pay for it. Oh well, anyhow... That tutorial needs to be flagged important so everyone with this headlight issue whom doesn't want to pay $500+ can follow it and fix their Vette.
Thanks guys, I love this forum. (my next fix is the Fuel Sending Unit, yes I bought the Vette with these 2 very common problems. But I've already found the step-by-step youtube video for the sending unit)
Supporting Vendor
Location: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Congrats! The shame also is how much some are charging to repair. My last fuse block I bought was around $275.00 new and you see what little is involved in actually replacing the whole unit, maybe an hour tops.
It's more like ten minutes tops. Five if you'd done it before. New ones come with all fuses and relays installed, so it's really quick.
So what exactly does this broken wire control??? Is it one of the two lines that control the headlight relay? I think it's just amazing that the wire always breaks in exactly the same place...
So I went ahead and decided to tackle this issue myself. Especially after the dealer telling me it was $535 for a whole new fuse box! Big thanks to senseoftouch for his step by step. Only thing I did different was use tin snip for the un-swegde portion. Made several cuts in each one and the screws came right out. Was able to hammer them back in afterwards. And because of my OCD took a pic on all the fuses in place, then took them out and laid them in order on my workbench. Also used stranded wire because it was easier to bend. Took about 1 1/2 hours but I'm all good now and spent a mear $12 on this fix. Cost of a 12 pack .
Stranded wire was one of my thoughts as I followed this issue over the years. Haven't seen anyone use it before you though. Makes sense if the solid wire has a problem in the same spot in all the boxes.
So, is there a difference in the performance of solid wire vs. stranded wire, electrically speaking? TIA for any info you may have.
When I went to purchase the solid wire and explained the reason behind it the guy at Home Depot said the stranded was better because of flexibility (when expanding because of the heat) and easier to bend. I had 14G stranded in the garage, stripped it down and took out three strands which I wrapped together. When putting it in place I used a very small flathead screwdriver to pop into place and hold down when I bent the wire. Really was much easier than anticipated.
It's probably sufficient to grind out the little plastic grid square where the curve is. That would give the wire room to move.
I wouldn't mess with stranded conductors. The fuse box has punchdown terminals. They make good connections but you have to use exactly the right gauge wire, or else you'll have traded one source of intermittent continuity for another.
1 Post
Yes Jim, the cover is just snaped in place. A small flathead screw driver to gently pry it apart works fine. I had to pull mine apart to get to the fuel pump wire that was intermittently shorting out. Wire and connector looked fine once I opened it up. So I just bent the connector back for more snug fit, a little dielectric grease and it was good to go.
If you have to pull wire(s) loose, there are plastic locks on the side that hold the connectors in place. Be careful not to let other wires escape as it's a cluster**** of wiring. Better yet take a couple pics so you know which wire goes where just in case one escapes.
