Moving TPMS to new wheels?
Old Jul 13, 2013 | 10:43 AM
GM TECH's Avatar
GM TECH
Default Moving TPMS to new wheels?
Tried the search....no luck. I am putting a new set of wheels on my 2013 GS Coupe. I am moving the TPMS sensors to the new wheels. I have the required new valve stems. Is it necessary to maintain the sensor positions? In other words, does the sensor from the driver's side front need to go in the new wheel that will be mounted at this position?
Thanks for your help.
Cheers - Major Boyd
Old Jul 13, 2013 | 11:02 AM
dennis50nj's Avatar
dennis50nj
Cheers - Major Boyd
Yes! unless you are recoding them with the tpms tool
Old Jul 13, 2013 | 11:18 AM
truckplay's Avatar
truckplay
if you don't you will have to reprogram them. just mark them & swap them into the new wheels.
Old Jul 13, 2013 | 11:59 AM
GM TECH's Avatar
GM TECH
Thanks.
Old Jul 13, 2013 | 04:33 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Cheers - Major Boyd
Did you mean "Valve stem seals"?
Or "Valve stem nuts"?
Of course, the stems themselves are an integral part of the sensor assembly.
Old Jul 13, 2013 | 10:18 PM
GM TECH's Avatar
GM TECH
Thanks for raising the flag. My Chevy parts guru sold me four valve stems GM PN 15263240 stating this is what I needed to relocate the TPMS sensors to the new wheels.
I'm gathering you're about to tell me that I only need the new seals....
Am I reading you correctly? ....and thanks.
Cheers - Major Boyd
Old Jul 13, 2013 | 11:09 PM
dennis50nj's Avatar
dennis50nj
gmpartshouse lists that part number for this
http://store.gmpartshouse.com/parts/...agramCallOut=2
Old Jul 13, 2013 | 11:10 PM
dennis50nj's Avatar
dennis50nj
that part number comes up at gmpartshouse for this
Old Jul 13, 2013 | 11:43 PM
BEZ06's Avatar
BEZ06
Cheers - Major Boyd
Your Chebie parts guy is no guru!!!
Take those valve stems back, because the guy doesn't know WTH he is talking about!!
Your sensors look like this:
Your car is not very old, and I would bet that the grommets on your sensors are perfectly fine to use in your new wheels. However, your tire shop that mounts up the tires onto the new wheels may want to sell you a "rebuild kit" for about $6 or $7 per wheel - it looks like this:
The only thing you might possibly need is the grommet at the right of the picture above.
When the sensors are removed from your OE wheels, take a look at the grommets. Unless they are cut or badly distorted I would use them in the new wheels.
As mentioned in earlier posts, if you keep the sensors on the same corner of the car they are on now then nothing at all will need to done.
If they get mixed up they'll still work fine - but if the sensor that was programmed into the TPMS computer memory in the car as the Left Front is now on the Right Rear, if the DIC says "Left Front 20 psi" it will really mean that the Right Rear is the one with low pressure.
If the sensors do need to be reprogrammed into the TPMS because they get mixed up, it's about a one minute procedure to reprogram them.
Bob
Old Jul 13, 2013 | 11:47 PM
Gearhead Jim
St. Jude Donor '13
Cheers - Major Boyd
Well, the valve stems on a C6 are the threaded part that sticks out from the wheel. On older cars, rubber. On the C6, aluminum and part of the sensor itself. You can't really replace them without replacing the entire sensor assembly.
You also have the gasket/O-ring that seals the sensor (stem) into the wheel, the nut that holds the stem in place, the valve core inside the stem, and the pretty aluminum cap.
Most good tire shops will install a "rebuild" kit when they move the sensors to another wheel, or often when they install new tires. The rebuild kit usually consists of a new O-ring, nut, valve core, and sometimes a cap. The kits are pretty cheap and probably a good idea. But they can't replace the most important part that eventually fails- the battery inside the sensor. When the battery starts to die, you buy a new sensor.
Old Jul 14, 2013 | 01:00 AM
1BADLS's Avatar
1BADLS
Cheers - Major Boyd
No. Any tire shop will reprogram the sensors after your tire install. Weekly, I switch out my tires or race tires. I reprogram the sensors with a tool I purchased from West Coast Corvette.
Old Jul 14, 2013 | 10:09 AM
GM TECH's Avatar
GM TECH
Thanks for all the input Guys (except maybe the Camaro link )
Old Jul 14, 2013 | 11:06 AM
dennis50nj's Avatar
dennis50nj
I put the part number you gave in the gmpartshouse website. GM PN 15263240 and that camaro link is what came up, so your parts guru gave you the wrong partor the site is wrong
Old Jul 14, 2013 | 02:19 PM
GM TECH's Avatar
GM TECH
So we all agree, my parts guy is a dunce
Old Jul 14, 2013 | 06:22 PM
dennis50nj's Avatar
dennis50nj
we all agree and we never met him. You should show him this thread
To Moving TPMS to new wheels?
