need help with lighting project.
So I am trying to wire up my side marker lights to blink when I activate my turn signal switch. I recently received a set of DIC's(Dual intensity circuit) that have one wire labeled to go to the LED device(my side marker lights) and two wires on the other side of the DIC labeled for the parking lights and the other wire for the turn signal wire. Anyone know what color wire or have a wiring diagram that shows which wire is for the parking lights? And the turn signal lights? front and back?
thank you for your help. I will do a step by step thread for anyone interested in accomplishing the same.
maybe Southwest Speed can put this together for everyone once I can sort out the wiring and work out any bugs, Thanks Ivan and Christa.
