Need 08 C6 coupe manual steering column/ steering angle sensor wiring Schematic
As the Titles states. I recently did a clock spring and steering column harness replacement for steering wheel audio controls. The harness I got from gm was different so I rewired the new harness for the pinouts for the steering angle sensor. I am getting service active handling light now. Can someone help me out with a column/ steering angle sensor wiring schematic for 08 manual coupe. It would be greatly appreciated.
As I said to the other fellow, this is from my 2007 GM service manuals. All I can find is the connector diagrams so make of this what you will.
The steering position sensor connector:
http://www.darkmars.com/cf/steer_sensor_connector.jpg
http://www.darkmars.com/cf/ebcm01.jpg
http://www.darkmars.com/cf/ebcm02.jpg
http://www.darkmars.com/cf/ebcm03.jpg
http://www.darkmars.com/cf/ebcm04.jpg
Hope that helps.
Z//
Hope that helps.
Z//
Still no luck! If anyone one has the 2008 under dash connector from the steering column harness plus steering angle sensor to the under dash harness would be helpful. Thanks
Supporting Vendor
Location: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
There is also a problem with the connector in that the wires are sometimes loose and can set the cel Especially service active handling light. GM makes a comb style clip that is inserted into the connector and tightens up the pins.
Thanks for the pin out! I already have that info. I specifically need where the column harness meets to the under dash connector. Sorry if I wasn't specific enough.
