C7 Z51 active handling ABS
Old 05-19-2014, 06:02 PM
The Bus
The Bus's Avatar
Default C7 Z51 active handling ABS
I've owned the car for 8 days now and have been on the track [ PIRC ] two days.
I pulled the fuse to disable the active handling but I also didn't have ABS.
Was not a problem but it still would be nice to have the ABS. I was told that there was a way to have the ABS without the active handling. How??
The car ran within 3 seconds of what I ran with my C4 race car. ELATED
Old 05-19-2014, 06:20 PM
glenB
glenB's Avatar
St. Jude Donor '08-'09 & '12, '14
You know you're in the C6 section?
On the C6 you can turn off the nannies with the Traction Control button on the center console
Old 05-19-2014, 06:39 PM
The Bus
The Bus's Avatar
I have a C6. Sorry
The button still allows some active control. Maybe bad button circuit????
Old 05-19-2014, 06:57 PM
RicK T
RicK T's Avatar
Well, maybe you are doing it wrong. Here's how it's supposed to work:
1. Default mode when you start the car is TC and AH full on
2. One push of the button - TC is off
3. Two quick pushes of the button - TC off, AH in Comp mode
4. A long push and hold of the button - TC off, AH completely off
Old 05-20-2014, 05:32 AM
The Bus
The Bus's Avatar
I'll try it again on Friday. Back at the track.
THANKS
To C7 Z51 active handling ABS
Quick Reply: C7 Z51 active handling ABS
