About to do the Ranger method clutch flush for the first time
Sorry to say that I'm a little late to the party on this but I've never had a problem with my clutch and I just never thought about it until I came across some threads here.
I recently realized I should have done this long ago, but I don't race my car and don't drive it aggressively 'very often'.
I'm about to do the clutch fluid flush for the first time using the Ranger method.
I have the Flotool MixMizer and Prestone DOT4 synthetic brake fluid.
I have these Scott Shop towels. They don't specifically say that they are 'lint free'.
Will these work OK for cleaning out the reservoir?
Any thoughts or advice?
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Yes, they should work ok. Just remember to pack all the way around the reservoir, over the fender and even the floor where you'll have a bottle of some sort to put the old fluid into. I realize most won't do this but it's so easy for something to splash, spill (my Lexol bottle--not spray--just tilted over inside my DD), drop, drip, etc. And brake fluid can be caustic to paint and other things.
I don't know if it's just mine, but the Mix thing syringe is a little "sticky" which makes it a bit difficult to smoothly pull out, or push in when emptying. Thus, even more towels at the ready.
Also, I don't know if he was the first, but Chris, "cclive" has a method where he empties the reservoir, puts in new, and then goes for a drive. His logic is, you have to use the clutch pedal and it will mix and go in that way instead sitting in your garage pumping away 30 times. I've tried both; works both ways.
Yep. Get an empty bottle to drain fluid into. I find a water bottle is held nicely on the side of the brake master. I use regular paper towels too but yours are better. Don't drip fluid on the paint and if you do wipe it quickly and you should be ok. The fluid comes out of the syringe with some force so put the tip way in the receiving bottle.
Great! Thanks for the responses.
I'll get it done tomorrow.
I'll be careful to protect the paint and try not to spill any.
Yes, I figured to go for a little drive to mix it up and then do it again.
That's a good plan. Then if you do it after each drive for a few drives it'll get to where it stays mostly clean and you can just do it every so often. I've been doing it infrequently for 8 years now and it stays pretty clean.
Small slit in the dot 4 top foils, instead of removing the top foils, does wonders to regulate the fluid coming out the bottles.
Understand too that when withdrawing the Mix Mizer that fluid can drip out the hose end.
The syringe will not hold all the fluid in. You will have to place your finger over the end to stop the fluid from leaking out.
I have tried a number of different types and they all reacted the same way.
Might just be me....
St. Jude Donor '15
"In honor of jpee"
I have done this thousands of times, never any fluid on the paint.
Since I am ****, the following is opinions due to my compulsive OCD nature:
1. Instead of using what is commonly used by others. Aside from brake bleeding, Mityvac Brake Bleeder Kit is useful with vacuuming out clutch fluid. To prevent drip, just invert siphon hose and empty into container of your choice.
2. Other than using virgin lint free cloth, paper type products will have lints. Since there is contaminated fluid down stream of reservoir, rather than the risk of introducing unwanted lints/contaminates into clutch system, there is no need to wipe inside of reservoir, simply refill after siphoned. Unless there are chucks of particulate.
3. Clutch pedal action will result in wear with everything connected down stream of the pedal, each and every time. Much better to drive after each refilled then to pump with car not being used. Depending on how contaminated it was, it will take time and patience, but it will eventually cleared up.
4. Also a good idea to provide vent holes to the two front plastic covers on the bell housing. While car is in motion, flow thru air will evacuate clutch dust as an passive bonus.
I use a topsider to drain my clutch fluid reservoir when doing this, seems to offer the best solution for not losing brake fluid on parts of the car where it is not desired, cover the fender with a towel so the hose does not contact the paint.
