Smelly air conditioner
Old Sep 21, 2014 | 10:24 PM
CorvetteTony2008's Avatar
CorvetteTony2008
Default Smelly air conditioner
I have an oily smell coming through my air conditioning vents; the problem started after the dealer replaced the oil pan gasket under the power train warranty. I brought it back after I drove it for awhile hoping the order would disappear. They replaced a filter and said they didn't notice a problem, but the problem is still there. They examined the car for oil leaks and said they could not find a problem. What could cause this problem? Would recharging the system help? I have an extended warranty until 8/15, but does not cover recharging. Could it be the compressor? Any help is appreciated.
Thanks,
Corvettetony
Old Sep 22, 2014 | 12:19 AM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
Take it back to the dealership and MAKE them fix it, end of discussion. If they do not then call customer service in Detroit they will get it done for you, ask me how I know.
Old Sep 22, 2014 | 02:04 AM
CorvetteTony2008
Default How do you know?
How do you know? I would like to know what the possible fix is?
Old Sep 22, 2014 | 10:28 AM
CMY SIX's Avatar
CMY SIX
did you change the cabin filter?
Old Sep 22, 2014 | 12:18 PM
torquetube's Avatar
torquetube
You're probably smelling spilled oil from the engine compartment. How many miles has it been since the service?
Old Sep 22, 2014 | 12:27 PM
cpetruzzi's Avatar
cpetruzzi
Thanks,
Corvettetony
They probably spilled some oil on the exhaust pipes. It should burn off after driving for a while. If not, bring it back.
Old Sep 22, 2014 | 03:34 PM
CorvetteTony2008
Yes; did not help.
Old Sep 22, 2014 | 03:37 PM
CorvetteTony2008
Thats what I thought at first; its been 5K miles and very little change.
Old Sep 22, 2014 | 03:42 PM
CorvetteTony2008
Its been 5K miles; they changed the filter 1K miles ago and still there is an odor. Can the compressor omit odors into the system?
Old Sep 22, 2014 | 09:39 PM
dmoneychris's Avatar
dmoneychris
http://www.fram.com/air-filters/fram...ir-filter.aspx
To Smelly air conditioner
