Stuck driver window
Stuck driver window
Okay so I've ran into the problem before where the windows get stuck up and won't come down when you try to open the door. But now the driver window won't go all the way back up and won't reset like when I reset them when they get stuck up. Any thoughts? Or know how to get it to go all the way back up? Thanks
The easiest thing to try is disconnect the battery for at least 30 minutes, reconnect, re-index the windows and hope.
Example:
https://www.corvetteforum.com/forums...-indexing.html
Example:
Received 8,930 Likes
Check the voltage being delivered to the driver door module inside the door. It it isn't correct it could cause a problem (wiring or connector issues could cause a voltage drop). Otherwise you are probably looking at a new door control module. The module controls door and window opening.
Bill
Bill
