LG Coil Over Install not going well
OK - so its done
All -
Thank you all for the support/discussion.
Anthony helped my by supplying a video where the upper control arms are lowered - I had already gotten the lowers off in the front although I did garf a boot using a pickle fork on the passenger side.
I would not and will not use a fork in the future on anything - I should have gotten a ball joint separator but I got impatient and it cost me.
Dropping the upper control arms on the rear was much easier than trying to deal with the lower control arms.
I did struggle with getting the end links on the rear stabilizer bar but some advice and a jack helped that.
I would like to thank Anthony at LG for talking me through the effort - he was very helpful and he knew I was frustrated with the control arm issues.
best -
best -
I've always tapped the nuts like someone else suggested above. If it was only to remove the spring, cutting the spring could have been an option if it was that bad.
