Widebody Conversion Question
Hi all,
I did a wide body conversion on my 2005 base. Z06 sized rubber all around.
My question: If I do not change the sway bars and shocks, will it cause any damage to suspension?
I understand that I am sacrificing track/cornering performance by not doing the sway bars and shocks.
Thanks!
Thanks!
I have a 2005 running Z06 rims/tires, I have the Z06 sway bars, Bilstein shocks and base springs. Honestly, it is actually a pretty good compromise, very little body roll and you don't get the harsh ride of the stiffer springs. That being said, I don't believe you will damage anything. However, from what I understand the Z06/GS sway bars are specifically tuned for the wider tires as well as the difference in tire size between front/rear. So if anything I would definitely recommend picking up a set of Z06/GS sway bars. Hope this helps!
Thanks Ataractic. Yes, that does help. I'm going to keep my eye on the 4sale area for someone swapping out their Z06/GS sway bars for something stiffer.
Premium Supporting Vendor
We sell the Z06 sway bars and bushings for $281. You can check them out and order at the link below..
http://www.cultragfactoryparts.com/c...kit/c6z06bars/
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
