TPMS Confusion
TPMS Confusion
I did all the searches and nothing seems to address my particular situation.
Car: 2008 Z06
I just put new tires on the car with different wheels and pressure sensors.
I went through the relearn procedure and when I was done I realized that the car was not honking. The tool (TIPS) was acting fine.
So, I tried it again. The car did not honk when I pressed and held the Lock and unlock buttons. No indication that it was in relearn mode.
Question 1: is there supposed to be a message on the DIC when it goes into relearn mode?
I drove the car for a half hour at all different speeds. There was no messages, no lights, and the tire pressures seemed to be reading OK. They went up from 30 to 32 as I drove and while I was sitting at lights they came down to 30/31.
Question 2: Did it learn the new sensors without honking the horn?
I'm so confused.
Car: 2008 Z06
I'm so confused.
Car: 2008 Z06
I'm so confused.
Car: 2008 Z06
I'm so confused.
I changed wheels and tires years ago, went through the learning TPMS process, and couldn't get the last tire to honk, AND got the Service message. Tried it over and over, car was only reading three wheels. GAH DAM!
Turns out my tune in the PCM was locked which won't allow the car to relearn new TPMS without unlocking first.
Good luck!
Keith
I recently put new tires and tpms on my 2005 and when I went to programmed them the same thing happened to me. Put in acc, hold lock and unlock, no horn honk or dic indication but when I went around each wheel the horn honked and all is fine.
If your car is performing fine, reading the sensors, not throwing service TPMS messages, who cares if the car honked or not...
Good luck!
Keith
Good luck!
Keith
I'm getting new wheels for my '13 that has the Diablo Intune, engine and tranny tunes. Will that create a problem when they "relearn" the sensors on the new wheels? Asked the question on Diablo forum, as well. Easy enough to return the car to stock first, but don't want to if it isn't necessary. You didn't mention what tune you had, but glad I read the post to ask the question!
Car: 2008 Z06
I'm so confused.
Car: 2008 Z06
I'm so confused.
One other question...is your horn working? If not, then the whole thing could happen without notifying you.
Received 8,929 Likes
Bill
If you truly had it in learn mode having your old sensors near the car would not have caused an issue. In learn mode the car is waiting to receive a signal from a tire pressure sensor and it is highly unlikely that one of the old ones would wait to transmit at the same time the car was waiting to be reprogrammed. A fair number of programming tools don't indicate the sensor broadcasts a message. The car honk is the only way you know the sensor made a broadcast.
Tire Pressure Indicator Sensor Learn
Learn Mode Description
The Tire Pressure Monitor (TPM) System uses the keyless entry transmitter, body control module (BCM), remote control door lock receiver (RCDLR), 4 radio frequency transmitting pressure sensors, and the serial data circuit to perform the TPM learn mode functions. The sensor learn procedure must be performed after every tire rotation, RCDLR replacement, or sensor replacement. Once the learn mode has been enabled, each of the sensors unique identification codes can be learned into the RCDLRs memory. When a sensor ID has been learned, the RCDLR sends a serial data message to the BCM to sound a horn chirp. This verifies the sensor has transmitted its ID and the RCDLR has received and learned it. The RCDLR must learn the sensor IDs in the proper sequence to determine correct sensor location. The first learned ID is assigned to the left front location, the second to right front, the third to right rear and the fourth to left rear.
Sensor Functions Using J-46079
Each sensor has an internal low frequency coil. When the J-46079 Tire Pressure Monitor Diagnostic Tool is used in activate mode, it produces a low frequency transmission that activates the sensor. The sensor responds to an low frequency activation by transmitting in learn mode. When the RCDLR receives a learn mode transmission while in TPM learn mode, it will assign that sensors ID to the location on the vehicle relative to the order in which it was learned.
Learn Mode Cancellation
The learn mode will cancel if the ignition is cycled to OFF or if more than 2 minutes has elapsed for any sensor that has not been learned. If the learn mode is cancelled, the original sensor IDs will be maintained. If the learn mode is cancelled after any sensor is learned, the DIC will display dashes instead of tire pressures for the remaining unlearned sensors and the learn procedure will need to be repeated for the system to function properly.
TPM Learn Procedure
Important: Before proceeding, ensure that no other learn procedure is being performed simultaneously or that tire pressures are not being adjusted on another TPM equipped vehicle within close proximity. Stray signals from other TPM equipped vehicles just driving by can be inadvertently learned. If any random horn chirps are heard from the vehicle while performing the learn procedure, most likely a stray sensor has been learned and the procedure will need to be cancelled and repeated. Under these circumstances, performing the TPM Learn Procedure away from other vehicles would be highly recommended. In the event a particular sensor activation does not cause the horn to chirp, it may be necessary to rotate the wheel valve stem to a different position due to the sensor signal is being blocked by another component.
Place the electronic keyless ignition in the ACCY position.
Using a scan tool, initiate the TPM Learn Mode. A horn chirp will sound indicating the Learn Mode has been enabled.
Starting with the left front tire, hold the antenna of the J-46079 aimed upward against the tire sidewall close to the wheel rim at the valve stem location. Press and release the activate button and wait for a horn chirp.
After the horn chirp has sounded, repeat step 3 for the remaining 3 sensors in the following order:
• Right front
• Right rear
• Left rear
After the LR sensor has been learned, a double horn chirp will sound indicating all sensors have been learned.
Place the electronic keyless ignition in the OFF position to exit the learn mode.
After the learn mode has been exited, adjust all tires to the recommended pressures. Refer to Vehicle Certification, Tire Placard, Anti-Theft, and Service Parts ID Label .
TPM Learn Procedure
• Right front
• Right rear
• Left rear
Got it. Thanx Bill and Floss. Didn't think so, but the referenced post got me wondering.
That's interesting Bill...that procedure is different than it is on my car. I hold the lock and unlock button on the fob after putting the car in ACC. I wouldn't know how to use the TPM tool to put the car in learn mode.
Update:
Went to the track over the weekend and all was fine. Sensors worked fine. 125 miles to track, 150 miles on track, 125 miles home.
I came home and swapped wheels and tires but did not reset the sensors. I drove for a while and no pressure changes were registered. The values stayed at about 30 lbs.
I rest the sensors same as before, no honk, no DIC message. Pressures immediate changed readings to about 34 and they change as I drive.
I have to assume it is in learn mode and learning without the honks.
Horn works, guy on freeway learned that when he tried to change lanes while talking on his phone. I hope he didn't break it when he dropped it.
I use the option that the horn does not honk when the car locks. I wonder if that is connected.
Bill
They aren't talking about the TPMS tool. When they say scan tool they are talking about the Tech 2. That is why the Tech 2 is such a powerful tool, it not only reads codes and data it also commands the car to do certain things and in some cases can determine if the car responded properly to the command.
Bill
Bill
