Throttle Body help!
Throttle Body help!
I was wondering if i could install a 2009 ls3 throttle body on my 2008 ls3. i read that the 2008 has the silver flap and opens in the opposite way as the 2009 which has a bronze flap. will i have any problems?
Before you do anything make sure the blades are not the same, the newer cars are gold, so they may be the same.
My 08 has a LS2 TB (Sliver Blade) If you put a LS3 TB on you will have problems because the electronics are different in the LS3.Maybe a tuner can help,I don't know? Again you will have to pay the tuner, not worth it.It has been said that the LS2 is a better TB..
I don't know if all the LS2 throttle bodies are the same, but check out this video.
