best remote bleeder?
getting ready to do a clutch in my 05, who has the best remote Bleeder? I am leaning to the Katech, a little pricey but don't want to do this twice. Just wondering what everyone is using. Thanks everyone.
Abel Chevrolet here in Northern CA installed a Mantic dual disc clutch that I supplied and they recommended that I also install a remote bleeder. They installed a Katech remote bleeder and it is made of a quality stainless steel braided line. I have had no reason to bleed my clutch, but when I do it will be a breeze.
Received 1,194 Likes
St. Jude Donor '15
Katech and Monster make a nice one. I have the ECS one and it's fine too
I would go with the Katech or Monster one if I were doing it over again.
St. Jude Donor '15
You aren't getting one on without the torque tube being removed
I am confident that someone will tell us they did, but I don't believe the average person can.
Katech,
It has a low profile at the turn, and you don't run into problems with clearance problems at the bend.
FYI, also heat shield sleeve it until it exits the top of the fire wall and you route the end under the driver fuel rail cover. This way if it come loose/starts dancing and end up near one of the headers/exhaust pipes, less likely to burn through it instead (same reason the the lower line for the slave off the master is heat shielded sleeve too).
St. Jude Donor '15
Good idea. I may add some heat shielding to mine today. I would hate to ever have to replace that thing due to it getting too hot.
