LS2 stock bottom end LS3 top end
Old 04-07-2016, 08:45 PM
Last 1
Last 1's Avatar
Default LS2 stock bottom end LS3 top end Dyno Results
LS2 stock bottom
Thanks to Bobby and Blue-Cat for the help and tune at Kentucky Speed of Pikeville, Kentucky
Old 04-07-2016, 10:26 PM
sallen619
sallen619's Avatar
What cam did you go with?
Old 04-07-2016, 10:59 PM
Last 1
Last 1's Avatar
comp cam kaotik 235/243 /620/624-113+2 ls 7 lifter the heads CNC Chevy Preformance LS 3 milled .30 thou
Old 04-07-2016, 11:11 PM
sallen619
sallen619's Avatar
Very nice numbers!
Old 04-09-2016, 09:10 AM
Last 1
Last 1's Avatar
as soon as I install my 410 gear i'll do the true test
Old 04-09-2016, 09:56 PM
xBoostx
xBoostx's Avatar
Hey man those are super numbers for an ls2 congrats, now if you think gears will increase your dyno numbers you are thinking like I did but I was in for a surprise found out gears reduce resistance which is what dyno measures, I went from 3.47 to 4.10 gears and power went from 643 whp to 586
Old 04-11-2016, 03:09 PM
0Daniel@Vengeance
Former Vendor
Daniel@Vengeance's Avatar
Those are great results! Congratulations!
If anyone would like more info on this camshaft as well I have listed a link below:
http://vengeanceracing.net/vengeance...624-113-2.html
- David @ Vengeance
SteveDoten@ARH (04-14-2016)
Old 04-11-2016, 11:10 PM
sallen619
sallen619's Avatar
How does your car drive now? On the street and highway...
Old 04-12-2016, 09:47 PM
Last 1
Last 1's Avatar
you need a 410 gear for good performance and driveability, a 342 gear is to high for the cam for freeway driving in my car. Good job on cam spec Dave! Question I wander if fly cutting the pistons help at low lift unshroud the valves in a 4" bore.
Old 04-17-2016, 10:25 PM
z06scentair
z06scentair's Avatar
fantastic results!
Old 04-30-2016, 03:36 PM
07silverc6
07silverc6's Avatar
Great numbers. Wondering how close the piston to valve clearance is? I am doing the same thing with the G8 heads. I'm going to mill them 10 to 20 thousandths and I am concerned about it. I only have the Texas Speed MS3 cam with 111.
Old 04-30-2016, 03:39 PM
z06scentair
Seems like he told me he flycut due to lack of clearance, somewhere around .050" before he cut.
He will chime in and let you know.
Old 05-01-2016, 09:15 PM
Last 1
Last 1's Avatar
I had to cut mine 95 thous which only gives you about 75 usable clearance , i had 30 th when i started. The best info i can give you is to go to post #17 , dyi section label fly monster. Good luck with your build.
Old 05-02-2016, 10:37 PM
07silverc6
07silverc6's Avatar
Thank you for the information.
To LS2 stock bottom end LS3 top end
Quick Reply: LS2 stock bottom end LS3 top end
