[Z06] I May Have Screwed Up My Exhaust Actuators
I bought a Borla X-Pipe and had it Jet-Hot coated. I decided to have the stock over-the-axle muffler pipes, just up to the muffler, Jet-Hotted at the same time as the X-Pipe. When I picked the pipes and mufflers from Jet-Hot I noticed that the exhaust tips were discolored. I asked about it and they said, oh, that's because we heat everything up to 650 degrees.
Now the NPP actuators don't work with the Mild 2 Wild remote. It looks like the left one tries, but doesn't move the flapper. The right one doesn't seem to move at all. I was wondering whether anyone knows if there is a rubber diaphragm inside the NPP actuators that might have melted from the heat of the Jet-Hot process? Or maybe some shot blast material got into the vacuum lines in the actuator. Any ideas?
If I did screw them up, can the actuators be replaced? Or will I need to replace the entire muffler sections?
Does anyone have a set of 09 Z06 mufflers they want to get rid of?
Thanks for any ideas on what might be wrong with them or mufflers you might have lying around if you replaced your stock '09 mufflers.
Steve
Steve
Steve
Steve
