[Z06] 2013 brings the ULZ 700 3.9 project
Supporting Vendor
St. Jude Donor '09
This is my project for 2013. 3.9lbs/hp is our naturally aspirated ultralight build, without sacrificing performance or street manners, with looks to kill, and totally stealth to the untrained eye.
We have a new ZL1 intake to build at Katech next year, and a C7 intake in CA as soon as the C7 arrives. In the meantime, a trip to Katech will put our ULZ700 from crazy fast to insane.
Halltech ULZ700
3.89lbs/hp 2779lbs/714 HP
E85 fuel exclusively
Katech Kavorka Cam K-501
Katech 13:1 Pistons with DLC wrist pins (4.130" 429 cid)
Katech hot honed case
Katech Carbon Fiber valve covers, Coil relocation kit
ARP Chrome Moly head studs and case studs, Titanium bolts and nuts throughout engine
Katech Rod (stock titanium) modification to the small end, H11 rod bolts
Katech High Performance Oil Pump
Katech Billet Aluminum Tensioner w/ titanium bolts.
C5R Heavy Duty cam chain
Katech Oil Squirters to the piston bottoms for cooling
FAST LSXR Intake (no porting) Katech Paint matched
WP 102 Billet Throttle Body /Halltech HNW102 Silicone Conn hose
Halltech Super Bee™ CF112/w Halltech Super Beehive™
Beehive PSI springs and Katech Titanium Retainers
HP lifters from Cadillac Racing
ZR1 Carbon Ceramic Brakes/w StealthTitanium caliper mounting bolts & bleed screws
Ultraleggera 19" front wheels/20" rears with 285 Michelin Pilot Sport Cup/335
Pfadt Carbon Fiber driveshaft
Pfadt Coil Over Suspension/Race Anti-sway bars
Pfadt Engine and Transmission Mounts
ATI underdrive crank balancer w/ ARP bolt
Caravaggio Race Seats/D Steering Wheel
Aluminum honeycomb Tunnel Plate with titanium screws
Titanium lug nuts/hood hardware/Titanium seat mounting bolts, alternator bolts, headers bolts, steering rack bolts and nuts, belt tensioner bolts, rear deck bolts and nuts
Kooks Headers mated to Akrapovic Titanium Xpipe and mufflers
Halltech ULZ Carbon exhaust tips designed for the AK EVO exhaust
EmailTune® tune by Jim Hall
Onboard E85 Wideband Dual O2 sensors
65lb/hr FAST injectors
FAST Billet Fuel Rails/Earls plumbing
Stock radiator w/160 thermostat
Iridium Plugs with Katech Plug Wires
Katech Aero kit, Carbon Fiber front rotor cooling ducting,
Halltech titanium Fascia Lift kit
Halltech Carbon Fiber Hive Port™ with full ram air modification
ZR1 Rear Spoiler
ZR1 Carbon Fiber Roof and pillar
Katech Carbon Fiber Deck Lid w/ Lexan rear window
Halltech GT2 Carbon Fiber Direct Radiator Exit Ducting Hood
Halltech ULZ Carbon Rear quarter panels w/ duct carbon reveal
Halltech Carbon Fender Ducts, Rear Carbon Brake Ducts, Carbon Gurney Flaps,
Torco Synthetic 5W40 Experimental Racing Oil with liquid molybdenum
Braille 340R Lithium Ion Battery 9lbs.
OS Giken Triple Clutch, Tick Master Cylinder, Tilton Slave with Katech upgrade
NEW-CARBON REVOLUTION WHEELS -47 lbs
Jim Hall
Halltech ULZ700
ZR1 Rear Spoiler
Jim Hall
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
262-510-7600
For service email:
orders@halltechsystems.com
www.halltechsystems.com
262-510-7600
For service email:
Wow. That car looks so nice. Where do I get a hood like that?
Supporting Vendor
St. Jude Donor '09
My Dad always told me "You have to like what you're doing." and I love my job, but man there are few things I wouldn't do to be building/engineering cars and parts like you guys do.
Supporting Vendor
St. Jude Donor '09
Some ideas fall short, some hit the mark, like our GT2 Carbon Hood, with 26 sold. Guess what? Every part I design, or fabricate for our car, satisfies me personally, which is all that counts in my world.
Wondering if you can do anything with the seat tracks, window glass, clutch pedal assembly, brake pedal assembly, hoses, pulleys, Tie Rod ends, etc. I assume you already have the lightest wheels and rotors you could find and would also assume you are not longer using run-flat tires. Just some thoughts and I am sure you have visited all these before, but maybe they are worth a second look.
Supporting Vendor
St. Jude Donor '09
I have started this new thread, since most of these ideas have been pondered or acted upon over the past few years of our build, or during our build off against Katech. That thread is up right now but too many pages to go through for most new members.
Supporting Vendor
St. Jude Donor '09
About two minutes ago that thought occurred to me. It would make development longer and more expensive, but it could be done.
Why, would you be interested in wider flares? Wider tires? Looks, Just curious.
Aftermarket Starter
Do you save any weight there? I thought I saw them say like 8 or 12 pounds in weight. What is GM one?
Jim, your Z looks killer as allways Question, have you or do you make a rear diffuser for the Z06? Also, I guess you will weighing in a little lighter at Track Attack 2013
Supporting Vendor
St. Jude Donor '09
That is on our short list. The Tilton is the lightweight, but it requires their proprietary flywheel. I already have a OS Giken lightweight flywheel/clutch that weighs 28 lbs. vs. 56 lbs stock.
Supporting Vendor
St. Jude Donor '09
The problem is testing. I am looking for 7100 rpm and this cam has not been through their Spintron testing, yet.
Even if we see 20 RWHP, 10 from the CR bump, which is what we have seen before, and 10 or so from the heads at the .660" lift, that +40 is going to be stupid power. Generally I hate power that cannot be used, but there is always 1/2 throttle right?
Sometimes it is fun to go sideways in front of the Porsche GT3-RS 4.0 at 80 mph just briefly, to let them see you clean off the tires when they come to close. If that doesn't work, a good 15 car length pull in third and fourth will calm them down.
