C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Power steering hose routing.
Old 03-19-2013, 03:20 PM
nyerby
nyerby's Avatar
Default Power steering hose routing.
Putting my car back together after heads/cam and everything is fine except I can't seem to figure out which way the power steering lines route down around the rack. The U-shaped line is the one I can't seem to figure out. does it go underneath the rack and then out the front? Does anyone have a diagram for this?
Old 03-19-2013, 06:13 PM
pomppe
pomppe's Avatar
This I like to know too. I some how managed to put it back in place, but I'm not 100% sure I routed it the right way.
Old 03-19-2013, 06:28 PM
Buddy A
Buddy A's Avatar
If you have not figured it out yet, PM me and I'll take a pic of mine and email it to you
Old 03-19-2013, 06:34 PM
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
Can't help you on the hose routing.
But what did you end up having Texas Speed do to your heads? Did you stick to the following plan you mentioned earlier with the guides and the valves, or did you add something else?
http://forums.corvetteforum.com/c6-z...post1583187415
Old 03-19-2013, 06:55 PM
nyerby
nyerby's Avatar
I had them do porting,mill. 020,Stainless valves, and bronze guides. Update to follow when it is finished.
Old 03-19-2013, 07:19 PM
'06 Quicksilver Z06
Sounds like a winner.
Good luck with the install.
Old 11-22-2014, 04:26 PM
GunnerSMG
GunnerSMG's Avatar
I need a pic of this bad
Old 05-13-2016, 12:25 AM
db2xpert
db2xpert's Avatar
Default New PS hose routings and TSB
Hope this helps some people.
Attached pdf files.
The following 3 users liked this post by db2xpert:
Bingly (01-24-2017), RSVLT2 (11-22-2017), SteveDoten (03-30-2017)
Old 03-30-2017, 08:14 PM
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
Attached pdf files.
That is great info, I have noticed the low speed steering studder and have the old style hose.
On another note the 'old design' pressure hose is pita to install/remove. The brake lines make the routing a cluster.
Thank You Sir.
To Power steering hose routing.
Quick Reply: [Z06] Power steering hose routing.
