[Z06] high RPM stumble
high RPM stumble
I was at VIR this last monday and towards the end of the day i started noticing a little stumble at >5500 rpm
Its def not a dead cylinder like an ignition miss it just kinda stumbled a little and wasnt pulling like it should of been for the last few laps (felt mushy like it was pulling 10 degrees of timing)
CEL never came on and it idles and drives perfect at lower rpms
its an early 07 with 15k miles so im going to pull the valve covers and look around tonight, If no one has any other ideas ill hook up the wideband and log that and timing retard but its gonna be hard to really run it in the street like i was there
Any other ideas?
Any other ideas?
Thats funny I was specifically going to say it felt a little like a turbo car starting to blow the spark out.
i'll check the plugs too when i check the rockers.
Thanks!
Thanks!
I would pull the plugs and inspect them, I would also do a compression check while they are out and see if there is any one cylinder that is lower than the others, if there is you will need to dive in further.
so the car came apart for new valves and i just got it back together. I didnt really think that would fix the problem but it needed to be done and it got plugs in the process..
same problem. I really dont think its an ignition problem, like its not a single miss it kind of just falls on its face. Stopped up cats (only 18k miles though) or a fuel pressure issue come to mind. are there any known problems with fuel supply that i dont know about?
any other ideas?
any other ideas?
Is it possible you have a battery/charging problem and ignition is breaking down? Also, if you are runnung the stock intake/filter combo check to see if the stick on emissions pad inside the intake is starting to come loose.
Thanks ill check on that tonight..i feel like a partially blocked intake would have simular symptoms to what im seeing
I removed mine quite awhile ago. Was not easy.......
DH
so that wasn't it.. both pads are in tact. I need to log some passes with it but my laptop died the other day and I haven't gotten a new one yet.
any other ideas
thanks for all the help
any other ideas
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
any other ideas?
any other ideas?
This is what I would check and/or replace
- Cracked plug
- burnt plug wire
- bad coil
- low fuel pressure
- broken valve spring(s)
- bad ground, or loose ground connection
- Dirty MAF or bad MAF connection
I don't think it would be a plugged cat as they typically just loose power, not a cut out. I would almost think someone might have cracked a plug when they were working on the heads.
Can you give us any details as to the modifications on the car?
- Cracked plug
- burnt plug wire
- bad coil
- low fuel pressure
DH
- Cracked plug
- burnt plug wire
- bad coil
- low fuel pressure
Its not a miss like a plug or coil....it kind of falls on its face I'm thinking maybe its a fuel pressure problem but if never seen anything stock run out of fuel like that..
I have seen a voltage problem cause a pretty bad lean condition..but again not on a stock vehicle....I've also seen bad convertor have similar symptoms but with 18k miles I can't imagine that's a problem...it also isn't ratteling like the convertors comming apart
Thanks for all the help guys
And HP tuners won't run on that Mac lol...I need to go buy a computer and stop guessing
