C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Overheated Starter due to headers
Old 04-25-2013, 04:49 PM
Jawnathin
Jawnathin's Avatar
Originally Posted by erichg1000
The starter is accessable on pass side when the headers are off.
what wires melted on Driver side? I need to knwo so I can sheild them
I don't remember the name, sorry. But its close to the steering rack by the firewall. It has a black plastic wiring shield on it that got a little melty.
I will check my invoice from the shop when I get home as they did have to reorder the wires. It might have the name of the wires in there.
Is it not accessible with the headers on? Even on a lift?
Old 04-25-2013, 04:51 PM
Jawnathin
Jawnathin's Avatar
Anyone know when they moved from the plastic to metal cased starter?
Old 04-25-2013, 05:57 PM
Mark2009
Mark2009's Avatar
Originally Posted by '06 Quicksilver Z06
I've heard that wrapping the starter is a bad idea, as it traps in heat as well.
Heard that a fabricated heat shield is a better choice.
on both counts.
Old 04-25-2013, 06:04 PM
erichg1000
erichg1000's Avatar
I don't think it is. I could be wrong. But since I just pulled my headers off I am pretty sure. The starter is very tight between the exhaust and the oil pan/block. Its tight on the passenger side.
Old 04-25-2013, 06:09 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
15k miles on my LG 1 7/8"s and no issues.
Old 04-25-2013, 06:11 PM
LT5 John
LT5 John's Avatar
Lingenfelter has a heat shield you can buy for the starter, to protect from heat...
Old 04-25-2013, 06:12 PM
Undy
Undy's Avatar
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,095 Likes on 578 Posts
94K miles with my Kooks uncoated headers. The starter still cranks like it's new...
BTW... wrapping headers (stainless and mild steel) causes the metal to crystalize and causes it to fracture prematurely.
Old 04-25-2013, 06:14 PM
Mark2009
Mark2009's Avatar
The failure mode the OP described is a typical one for starters even on bone stock cars. Starts when cold, won't do much when hot (cranks slow or no). It's possible the headers have/had nothing to do with it.
However, if the starter is getting routinely cooked (by headers or whatever), it will eventually fail.
Old 04-25-2013, 06:15 PM
Mark2009
Mark2009's Avatar
There ya go!
Tell 'em where the starter is on an LT5, John...
Old 04-25-2013, 06:18 PM
Jawnathin
Jawnathin's Avatar
Thanks John, good to know about this option. Wish I would have known about this when everything was already taken apart.
I hope there isn't too much work involved to get this installed.
Here's the link...
http://www.lingenfelter.com/mm5/merc...5#.UXmrhbWPP-s
Old 04-25-2013, 06:31 PM
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
Here's the link...
I saw that one.
But nearest I can tell, there is no space between it and the starter case to allow air to pass through.
I was thinking something more along the lines of this, but it is for a C3:
http://forums.corvetteforum.com/1583647096-post16.html
Originally Posted by billcarson
(THE GOOD ,THE BAD AND THE UGLY).i replaced my original starter,of unknown origin,with a delco professional unit and installed it with a home made heat shield.no issues so far.THE GOOD-THE BAD-THE UGLY.(made in china)
Or this, which is for a Ford.
Keeps the heat off, but still allows the circulation of air along the surface of the starter, and the dissipation of heat from around the starter.
Unfortunately I know of no one who makes anything like this for a C6 Vette though.
Old 04-25-2013, 07:11 PM
LT5 John
LT5 John's Avatar
Originally Posted by Mark200X
There ya go!
LT5 motors are a biatch to work on...Everything on the motor is a hassle...Special tools designed specifically for the LT5 only...LOL, the starter is under the damn plenum, in the valley area...stuffed Under an LT5 plenum, is like 5 pounds of Sh*t in a two pound bag...
Old 04-25-2013, 10:11 PM
  #33
Scottkrough
Scottkrough's Avatar
I used the DEI starter wrap and have never had a problem since.
1-7/8 ARH
Old 04-26-2013, 07:18 PM
  #34
ATC399
Support Corvetteforum!
ATC399's Avatar
Originally Posted by Zel06
Has anyone had a problem with the starter overheating due to the headers? When I first start the car and drive it its fine. After driving it and they shut it off sometimes I have to wait awhile for it to cool off before it will start. Is it a good idea to wrap the headers? I already wrapped the starter but it does'nt seem to help. Any advise would be helpful.
FWIW..My bone stock 13Z is a very slow cranker when at operating temps.. it cranks but very slowly...when cold turns over like a champ...
Old 04-26-2013, 07:25 PM
  #35
Zel06
6th Gear
Zel06's Avatar
The headers are American Racing 1 7/8. I bought an aftermarket starter MSD with a new wiring harness and a heat shield.
Old 04-26-2013, 09:16 PM
  #36
gotjuice?
gotjuice?'s Avatar
St. Jude Donor '13
Over 4 years on mine with no issues. Gm has a heat shield for the solenoid that comes standard on the Escalades. It just snaps around it. That might be all you need.
Old 04-27-2013, 05:42 AM
  #37
songman3
songman3's Avatar
Here's how mine ended up:-
Not exactly sure why this happened - whether it was entirely a consequence of fitting headers[Kooks], or whether fitting the headers just hastened the demise of an already failing starter - I don't know.
The motor gradually became reluctant to turn over from stop - for obvious reasons when you look at the hopeless state of the terminal - the nut securing the battery lead was well loosel!
Ended up getting stuck at a gas station unable to start, and needing recovery truck back home.
Starter is easy enough to change from underside if you move the header aside.
To Overheated Starter due to headers
Old 04-29-2013, 08:02 PM
  #38
Mark2009
Mark2009's Avatar
Originally Posted by Bedouin
Anyone have any more info on this factory GM starter heatshield for the escalade?...sounds like the best solution yet, if it fits...
This may be a photo of it at this link (scroll down to pictures 3 and 4): http://www.fullsizechevy.com/forum/c...o-starter.html
You might also want to look into Moroso 74300 and Mr. Gasket 3678 (they appear to be about the same, but the Moroso may be more high tech). Moroso on the left:
The GM version (at the link; not shown here) looks like it just protects the solenoid. Dunno if any of these will fit.
Old 04-30-2013, 03:28 AM
  #39
Jawnathin
Jawnathin's Avatar
Any thoughts on just adding a layer of Thermal Tape/barrier by the headers? I just thought of this as I was doing adding some to some wiring that was getting a little too warm by the headers. I figure a few strips on the starter closest to the headers and leave the rest so it can 'breathe'?
I have some of this stuff laying around
Therm-Tec Thermal Shield Therm-Tec Thermal Shield
Old 05-01-2013, 12:48 PM
  #40
Pfadt Racing
Pfadt Racing's Avatar
I have some of this stuff laying around Therm-Tec Thermal Shield
A better idea than completely wrapping the starter I feel. A heat shield will block the radiant heat, but let the starter disapate any heat it generates on its own.
Quick Reply: [Z06] Overheated Starter due to headers
