[Z06] Tires and nitrogen
Tires and nitrogen
Have G2 Goodyears on my Z and had the tires filled with nitrogen.
Tire pressure 32# when starting out and parked in the shade/lawn at a car show for about 6 hrs no problems. After 15 minutes of driving home the fronts psi were 40/42 rears were 38/38. Problem?????
I would try another gauge to be sure there is that much change. Even with air and not straight nitrogen, that is a pretty large change unless you are driving from Alaska to Vegas.
- I thought for race cars the use of N was to better stabilize and predict changes in pressure as temp. change? which makes sense to me. But for the street or 99% of the people on this forum it makes no difference other than another way to waste money.
The earths atmosphere is almost 80% N as it is!
- Run Air in your tires and get a better gauge!
If u r on a long road trip the tire pressure is likely to increase, which can cause instability.
This one time i was on an hour trip, doing about 140, pressure went from 36 to 52... i changed my air to nitrogen the next day. It is also better if once in a while u track.
I find it interesting --why do people put N in their tires?
The push for street cars, iirc, is with air and varying temperatures you could get condensation inside of the wheel, and the air will "leak out" quicker than nitrogen will. So it was a low maintenance marketing pitch. I run air, because nitrogen isn't easy to find in Louisiana, while staying local it wouldn't be a problem, but when going to the track and changing pressures, etc... Plus I have my own air compressors, I don't have my own nitrogen setup.
Nitrogen is the biggest waste of money EVER. I learned it the hard way. I did it because of the high temp swings in Chicago (40 degrees in AM and could be 80 by mid day). And guess what, same pressure swings as with regular air.
Second that only I never paid for the Nitrogen. Had free access from a shop I worked with. laugh when its offered at the tire shops.
Nitrogen tire fills are a tax on people who don't understand physics. As long as you're not filling your tires with a mist of rusty water from an ancient compressor that's never been drained, there's no difference.
I agree with many here....if Nitrogen is free, close and convenient...use it....If you have to pay and don't track it then pass....for me it is close and free and it doesn't do any harm..........
check by your self then tell me ,,im waiting for your reply
☠☣☢ Semper Ebrius ☢☣☠
Pure N2 will experience a ~1 PSIG change for every 10 degrees fahrenheit of temperature change (at temperatures normally encountered).
Just like dry air.
Just like dry air.
Received 8,965 Likes
Nitrogen is a gas and expands with temperature just like any other gas does. It also makes up about 80% of the air in the atmosphere. When it comes to using it to fill your tires its big advantage is being predicable as to the increase in pressure with temperature due to being dry. The disadvantage of using air is the percentage of moisture contained in the air when your tire was filled. Depending on the weather that percentage can vary all day long. One time I had my C5Z on the track and was checking tire pressures every so often. Everything was consistent except the left front tire. Its pressure was 45 psi the first time checked. We lowered it by 8 psi and I made a few more hot laps and when checked the pressure had gone back up to 45. Dropped another 8 and did more laps. This time the pressure reached 40 psi (we were trying to get 37 hot). Finally broke for lunch and let the tire cool and then pulled the valve stem letting out all of the air and then refilled the tire. That solved the problem. The tire had been filled on a very high humidity day and had too much moisture and when it was refilled the humidity had dropped considerably.
Dry air or nitrogen can reduce tire pressure sensor failures since a number of the failures seen are due to corrosion of the sensor due to moisture in the tire.
Bill
Bill
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Lots of good and bad info in this trhread. But the ones who are telling you that N gives you problems are wrong. If they are seeing what they are seeing, it's due to something other than N.
Basically N, being 78% of the air we breath, is produced in a manner that dries the moisture out of it. That is the ONLY real benefit to using N. If the air compressor you get your air from has a dryer, then you will see the same pressure fluctuations as if you had pure N in your tire. AND, I would be willing to bet that those tires that were filled with N still have O, AR, and a few other components still in the gases in their tires. I have never seen a tire company pull a vacuum on a tire then fill it with N.
Smart move as noted is if it's free and handy, go ahead and use N, otherwise find a dry air source.
