[Z06] 647WHP - All Motor - No Nitrous , No Forced Induction !
Don't know if that's a friendly dyno or what. I did notice that they didn't list the cam used or mention cam specs. The MAST heads are good...but there are better flowing ones around. Ported FAST and NW TB are a dime a dozen so I'm thinking that the pulls were on a 100 shot.
Received 2,054 Likes
That's RattGs old C6Z and believe those numbers are STD, so ~3-4% higher than SAE...still a stout combo though as it went 9s on motor
Was thinking that was his old car... Yes STD.... Depending on weather can be ALOT higher...
That's beautiful! My favorite color too. Glad to see someone else is a "purist" like me and buys in to NA POWER. Whenever CID is out of the shop, he's expected to put down 650whp but on the SAE 2004 standard. His heads & cam numbers were inflated by the STD standard at 604whp. I'm looking for an honest SAE 650whp ALL MOTOR. We'll see... Been in the shop 6.5 months and counting . Maybe get him back before Christmas.. I HOPE!
Surely a stout combo but STD corrected numbers are inflated....my current N/A stock short block LS7 is 680RWHP SAE which is 696 STD!
what has been done since?
that was my old baseline dyno vid from this summer. car has under went a lot of changes since then
[QUOTE=JMB;1585463292]Surely a stout combo but STD corrected numbers are inflated....my current N/A stock short block LS7 is 680RWHP SAE which is 696 STD!
Is that a TYPO? Stock LS7's don't make 600+whp. More like 450whp...
Dyno numbers
Even if you correct for STD or SAE dynos can be different. I think the baseline is what does a stock Z do on that particular dyno and go from there. I have seen from a low of 420 hp to a high of like 460 hp stock.
