Carbotech brake pads coupon z28
#61
Supporting Vendor
St. Jude Donor '11,'13
Friday give us a call 216-780-8825...
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#63
Supporting Vendor
Happy Tuesday give us a call...
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#65
Supporting Vendor
Thank you all for the orders we appreciate it. Keep the phone calls, Emails, and PM’s coming we appreciate the opportunity to work with all of you.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#67
Supporting Vendor
Front and rear in 1521 compound is $509 in 1 piece design for these cars. Please call me at 216-780-8825 to order..
Carbotech have redesign the C6 Z06 One Piece pad for the front and rear stock calipers (PBR Calipers). Carbotech was the first to release the padlets almost four years ago, and then we were the first to release the One Piece over a year ago. That design that Carbotech worked with GM on wasn't perfect. That's the same design you see other companies using now.
Carbotech set out to redesign the new One Piece all on their own. Carbotech wanted to make sure it was perfect and even more user friendly. This new design will drop right into the caliper and you don't have to take out the caliper pins or spring clips. The spring clips are critical in keeping the brake pad square to the rotor surface and ensuring that the pads slide smoothly along the pins. The spring clips also assist in reducing the noise inside the caliper.
The one piece pad will make changing pads a lot faster and easier. The Carbotech One Piece pad will give longer pad life and a little more bite as well. Carbotech is molding the new One Piece pad just like they do with all the C6, C5, and C4 brake pads.
Carbotech is also using industry leading NRS technology. If you're not familiar with NRS technology it gives molded pads up to 8 times stronger sheer strength vs. conventional molded brake pads and riveted pads. NRS technology also helps in reducing noise and vibration of the brake pad inside the caliper as well as aiding in longer wearing pads. Carbotech use NRS technology on all C6 & C5 front and rear brake pads.
Here is a link to explain further what NRS technology is exactly: http://www.nrsbrakes.com
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#68
Supporting Vendor
Happy Monday
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#71
Supporting Vendor
Bump new month...
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#72
Supporting Vendor
Give us a call... 216-780-8825
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#73
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#74
Supporting Vendor
Carbotech brake pads is our business. Adam@Amp'dAutosport.com always offers the best customer service.. We combine superior customer service, speedy delivery, and the highest quality pad on the street or track. We can also accommodate special orders for any of Carbotech's compounds. Contact sales@ampdautosport.com for more information or call us direct at 216-780-8825.
Adam Adelstein
Amp’D Autosport.com
Cleveland, OH 44124
PH:216-780-8825
Web Site & Direct ordering:http://ampdautosport.com/
Adam Adelstein
Amp’D Autosport.com
Cleveland, OH 44124
PH:216-780-8825
#76
Supporting Vendor
Brake Pads Street or Track Amp’D autosport has plenty of Carbotech compounds ready to go. Take 5% off your order when using promo code z28 at check out or call us direct at 216-780-8825 to order. Pre bed option is also now available for all Carbotech brake pads. Looking forward to hearing from you soon. Please call or email us with any questions.
Direct link: http://ampdautosport.com/
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#77
Supporting Vendor
Open Saturday give us a call 216-780-8825 and as always 24/7 at http://ampdautosport.com/
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#78
Supporting Vendor
Tuesday.. TTT
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#80
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
