[Z06] ALERT !!! Do You Have Fairy Dust In Your Oil ??
This is NO JOKE !!!!!!!!!!
I have a black EE Catch Can. When I empty the can and look at the residual oil clinging to the bottom of the can there is a very fine GOLD GLITTER floating within it. You cannot see it if there is any depth of oil in the can. You cannot see it if oil is transferred to clear container. The oil had 3500 street miles. You have to hold the can in sunlight or use a flash light to view.
Here are some points to consider:
1. This is the same EE can used on my previous raced motor and my current not raced motor.
2. I have the same fairy dust then and now, been monitoring this for over a year.
3. Same for the stock and WCCH heads
4. Buddy has same EE can on modified motor and has the same but MORE fairy dust.
5. I used a strong magenet against the outside of the can and could not detect movement of the fairy dust. But maybe not strong enough.
6. Sorry did not try to get picture. Maybe somone else will or I will try in a couple thosand miles.
I think its the iron that we all see on our magnetic plugs. It looks fine enough to get through bearing space or any other part of the motor. The material could be alum, iron, bronze or titanium and it would likely look goldish due to color of the oil against the black can.
It is possible the the fairy dust could be comming from the EE can filter medium. I will try and contact them but the medium is shaved metal.
So I woud like to see if others can confirm fairy dust in their catch cans, any brand. It might be hard to see if your can is not black bottomed so maybe some one can confirm viewing on different color.
Opinions ?????????
DH
Opinions ?????????
DH
I would shake it up to insure the stuff in question is suspended in the oil.
Dump it into a clean container and send it out to be analyzed. If it's bearing material it won't be magnetic.
The whole point is that I have had it on my last two LS7 motor and the only other guy that I checked also has it. So the question is ... "Does Everyone have it and just don't know it? Maybe its related to guide wear!
DH
Shaking up won't solve anything.I have tested this many times, always completely cleaning the can. Wiping with clean clothe and rinsing with brake cleaner. You can not see it in suspension of any depth as the oil is too dark. You can only see it in the the remaining oil film on the can bottom after emptying the can.
DH
DH
Just installed an EE can on my car today, brand new top end for the car as well. I'll give my input as miles add up with pics if I see anything.
I beat the **** out of my car as well, redline it about once a day if not more, so if something isnt right, it will show.
Is your can Black?
You have to look close and put your reading glasses on if you need them otherwise you may not see it beacuse its so fine.
DH
But since the 3 motors I have checked have I thought other members would want to check their catch cans too.
DH
How long till you get a couple thousand miles? If you have cam or track it you obviously will catch enough oil sooner.
DH
I asked them and they said they could NOT analyse metal particles big enough to see suspended in the oil.
Do you have a catch can?
DH
Pro Mechanic
Pro Mechanic
Late at night, a faint voice is heard in Howie's garage.
"Hello...anybody there!? I'm my name is Tinker Bell and I'm trapped inside this engine...been here for months. I keep putting dust in the hose that goes to the catch can but nobody comes to rescue me."
And I know she has been in at least 3 motors.
Do you have a black EE can ??
We can check my can on wednesday but I will only have a couple hundred miles sonce cleaning it out.
DH
Opinions ?????????
DH
Opinions ?????????
DH
Mine had about 10x more than Howie's. His trapped oil had 3500 miles on it, mine had 2x the volume, 1 track day and about 500 street miles.
Doesn't bother me as much as it does Howie. I would just figure it was the bronze valve guides but Howie has powder metal type.
I have 75,000 miles on the lower end and 15,000 on the WCCH, in 25,000 I'm going to pull it apart and freshen everything up.
This motor runs like a 'Raped Ape' (we know raped apes are fast because no has ever seen one) puts down 545 RWHP.
I'm not too concerned with the motor it's everything else that breaks.
