[Z06] Texas Speed Long tubes w/stock cats/h-pipe?
Bought the car w/the Texas Speed LTs & offroad x-pipe on it. Have the stock exhaust too.
Need to put cats on for emissions. What are my options?
For example, in California (unless you "know someone" of course), they lift the hood on your car, find one hose out of place, BAM, fail. In that case, the only solution is stock.
If it is an OBDII scan for codes PLUS a tailpipe test, you MIGHT(!) get a way with aftermarket CATs, like the expensive "Green" CATs Kooks sells (they are just reselling another vendors product, you might find them cheaper). Again, someone that had a tailpipe test and that set up would need to verify if they will actually pass.
If is is just an OBDII scan, BAM, you are in the clear, no issue - if you do have codes or a CEL on your dash, that is from crappy installation / someone not knowing what they are doing - you just need someone to tune those out (yes, that means your car will be flashed and GM will know, but I assume you are not concerned about factory warranty at this point).
Anyone know is a Kooks catted x-pipe will work w/these headers?
Why wouldn't you just buy their complete system and add your own cats?
