C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Promising dyno results of my new LS7 heads
Old 04-29-2016, 08:44 PM
  #41
Undy
Undy's Avatar
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,114 Likes on 591 Posts
Originally Posted by zeevette
Yeah, but isn't Tony using Trickflow heads now?
I think everyone was trying to make an inference WRT Tony's abilities. He worked wonders for AFR so probably the same with TrickFlows.
Old 04-29-2016, 10:06 PM
  #42
Tony @ Mamo Motorsports
Supporting Vendor
Tony @ Mamo Motorsports's Avatar
Yes....Im using/starting with the TFS 260 castings because after flowing and working with alot of other LS7 castings, I felt the TFS head was the best starting point for me to create/design my product.
They allowed me to get the most air thru the smallest runner and anytime you can accomplish that you have moved mountains because the only way that happens is with alot of airspeed in the port from its extremely optimized shape/valvejob etc. (that's the only way a smaller port can outflow a larger port....the airspeed thru the port measured in feet per second is higher). Airspeed cleans up reversion.....packs and fills the cylinder with more authority but usually comes at the cost of peak airflow which usually dictates how much peak power the engine can make. In this case its a have your cake and eat it too scenario.....big airspeed.....big peak flow numbers for an explosive and extremely powerful combination.
Btw, I offer cathedral heads in my Mamo Motorsport line using both AFR castings and TFS casting depending on the product in question. I always use the castings that give me the most creative freedom and the best results for any given cylinder head architecture or design that I'm working on. AFR doesn't even offer an LS7 product so they were out of the running immediately.
To be honest, I was all set to launch my MMS LS7 head using Brodix castings but after porting and experimenting with the TFS castings I found I could get even better results at less cost to my customer.....another win win for you guys.
Hope this clears things up
Btw I have an awesome program for OEM castings also and have done alot of them over the years with good results but they were never as efficient as the new crop of LS7 heads I'm shipping now with the clean sheet aftermarket head offering me more metal in the right place.
Porting and designing heads isn't about just removing material....its also about leaving material in the right places to improve a ports flow potential (and efficiency). That's the only way I can finish a TFS casting at 265 cc's and have it outflow heads on my bench that are 20-30 cc's larger....which I should add is painstakingly difficult to accomplish but offers the end user soooo many upsides (more power everywhere in a much more explosive package.....better throttle response.....better tip in....less reversion/surging issues with large cams and even better fuel economy). Its the end result I am always striving for....creating the most efficient port that flows alot of air and its the general reason every AFR head I designed over the last decade and a half has kicked azz....I use the same winning formula whether Im designing a BBC head, an SBC head, a Ford head....an LS head....it doesn't matter!
Regards,
Tony
__________________
Please take the time to also visit my website at www.MamoMotorsports.com
The following 7 users liked this post by Tony @ Mamo Motorsports:
Buddy A (04-30-2016), Mr. Jean (05-01-2016), MTPZ06 (04-29-2016), pmj341 (06-16-2016), REDZED2 (05-04-2016), RGT (05-01-2016), zeevette (04-30-2016) and 2 others liked this post. (Show less...)
Old 04-30-2016, 12:02 PM
  #43
zeevette
zeevette's Avatar
Nor was I. I know well of Tony's expertise. I just have had a great experience with my TF 215s I now have on my C5Z, and was considering a C6Z in the future. Since I may need to replace the LS7 heads, I would probably go with Trickflows again.
Old 05-01-2016, 12:34 PM
  #44
Michael_D
Michael_D's Avatar
Tony
I really like hearing your comments above. I kinda got a woody when these heads were first announced with initial specs, but was waiting to hear some third party reports and flow data. I am curious though, when do you start worrying about sonic choke? Or is it even a possibility with these heads?
Old 05-04-2016, 01:00 AM
  #45
Supporting Vendor
They are good heads in stock trim......reeaally good heads after I rework/customize them (aka "Mamofied".....LOL). These heads start small offering me alot more creative freedom and when Im finished are still small all things considered but flow like gangbusters (410-415 CFM thru a 265 cc port!!).
They have out flowed every LS7 I have had on my bench thus far (when I'm finished with them) and do it with 20-30 less cc's then some of the other castings I have tested and I have had a very large cross section of LS7 product on my flowbench.
Win-win as I alluded to in my previous post.....its the killer combination....almost like a heavyweight fighter that can move like a middle weight. An almost un-natural goodness going on here and it does represent the best of both worlds.....big airspeed and big peak numbers as well equals an extremely efficient piece. That's the winning formula I have been relying on for two decades now
-Tony
Old 05-04-2016, 07:26 AM
  #46
double06
double06's Avatar
Default Exhaust port
Tony obviously the LS7 intake port in just about in any form flows very well and as you stated some even better than others. What about the exhaust port I do feel sometimes that is getting somewhat left out as approach 400 cfm on the intake and yet most of the exhaust numbers (with no tube or even with a tube add 15) are like 240-250. At what point do you do all this for the intake but we can not get it all out. I realize some of this is mitigated but a longer exhaust duration on cam but it would be nice to keep overlap down to and get same performance. Are we at a point were the 410 cfm really needs exhaust to flow like 280 (70%)?
Old 05-05-2016, 03:44 AM
  #47
Supporting Vendor
In a word.....YES....but its easier said than done. The LS7 designers focused there bias so much on the intake with the size and positioning of the valve that the exhaust was almost an afterthought.....LOL
While the large 2.205 intake valve is completely unshrouded from the chamber wall, that feature means just the opposite for the smaller 1.615 exhaust and it's "shrouded" pushed against the wall of the head which reduces the effective area of the valve being so close to the wall. Its just not ideal
I have invested alot of time on the exhaust side in an effort to better balance the flow relationship and my exhaust port flows about 265 CFM which is pretty solid on my bench (especially for an SBC head)....very solid in fact considering the geometry of the LS7 architecture which doesn't favor the exhaust port at all.
That said I do have to share that motors naturally aspirated respond more to gains in flow on the intake than they do on the exhaust and its interesting how low a percentage (exhaust to intake relationship) you can get away with cammed properly and still make alot of power. Pro Stock engines are perhaps the pinnacle of that example as the intake valves keep getting larger as the exhaust valves keep getting smaller....LOL Apples and oranges in some respects but relative to this conversation in others.
I would add I am working on an even larger exhaust port for my LS7 program but I am a long ways from completing it and confirming I can even pull it off without compromising the integrity of the casting (aka a port wall that's too thin that could effect reliability). I mention this only to further validate that I would love to have a higher flowing exhaust with a 415 CFM high velocity intake port, but my hands were tied a long time ago by the original designers of the head and their clear bias of "lets build a raised runner 12' head with a really kick azz intake port".
Btw on my flow equipment a stock LS7 flows about 372 CFM on the intake and 215 CFM on the exhaust. My new program using the TFS LS7 casting bumps that intake output by 12% or so (a significant gain with such a high baseline), and the exhaust by almost double that (23%), so the head Im offering does have a much better E to I relationship and requires less crutch with the exhaust cam timing than a stock head would require for optimal results.
Thankfully we have the cubes to offset some of the loss in torque the additional exhaust duration brings to the table....I suspect the designers of the LS7 recognized that and the fact intake flow plays a larger role in power output than exhaust flow
Good stuff!
Regards,
Tony
The following 5 users liked this post by Tony @ Mamo Motorsports:
Bad_AX (05-05-2016), Da Z06 (05-05-2016), double06 (05-05-2016), Mr. Jean (05-05-2016), pmj341 (06-16-2016)
Old 05-05-2016, 06:38 AM
  #48
Bad_AX
Bad_AX's Avatar
And THAT is one of the best discussions of LS7 air flow ever to appear on the forum or anywhere else.
Thank you!
Good stuff!
Regards,
Tony
Old 05-05-2016, 08:16 AM
  #49
double06
double06's Avatar
Default Exhaust flow
Thanks for the comment on this Tony. I guess if we can get the exhaust flow up to say 250 cfm with a tube that probably gets most of it out for NA purposes. Then we have to rely on the cam to finish it up.
Old 05-05-2016, 08:26 AM
  #50
Da Z06
Da Z06's Avatar
In a word.....YES....but its easier said than done. The LS7 designers focused there bias so much on the intake with the size and positioning of the valve that the exhaust was almost an afterthought............
Regards,
Tony
Good post Tony.
I have a question regarding the few documented failures of the Trick Flow head regarding to casting cracking.
Could you shed some light on this Tony?
Also, what valves are you recommending with the TM/TF head?
Old 05-05-2016, 08:53 AM
  #51
Bad_AX
Bad_AX's Avatar
Originally Posted by Da Z06
Good post Tony.
I believe Tony has commented on this already.
BTW, how many "documented" failures are out there? I recall only one that was posted here in the CF, and a reference to another one. It was not established that the casting were at fault.
Old 05-05-2016, 10:53 AM
  #52
Da Z06
Da Z06's Avatar
If he has, and you know the link please share it.
I do not know the number of failures but, I have "read" and "seen" pics of 3 different incidents. If there are more, I don't know. I can only speak of the one's I have "read" about. I'm curious to find out what caused the failures, possible cause and what was done to rectify it.
Old 05-05-2016, 11:50 AM
  #53
Bad_AX
Bad_AX's Avatar
https://www.corvetteforum.com/forums...estions-4.html
and
https://www.corvetteforum.com/forums...a-terra-3.html
If there was a systemic problem with the Gen X 260 heads, there would be a LOT of failures and an epic $hit storm on the internet. A logical mind would also rationalize that several other TFS LS heads would experience similar issues, but history tells us otherwise.
Old 05-05-2016, 11:59 AM
  #54
Da Z06
Da Z06's Avatar
and
Correct.
Thank you for the links.
Old 05-05-2016, 12:14 PM
  #55
olddragger
olddragger's Avatar
any resonance tuning changes? I would imagine there are?
Old 05-05-2016, 04:36 PM
  #56
myvette_99
myvette_99's Avatar
Good stuff!
Regards,
Tony
Tony, what does a wcch stage 2 flow on your bench and a stock ls7 trick flow head flow? Intake and exhaust? Would like to compare the flow with a stock ls7 and your mamo trick flows...thanks a ton!
Old 05-05-2016, 08:01 PM
  #57
Supporting Vendor
I'm going to PM you....
-Tony
To Promising dyno results of my new LS7 heads
Old 05-05-2016, 08:21 PM
  #58
Bad_AX
Bad_AX's Avatar
-Tony
Could you PM me as well?
Thanks,
Old 05-05-2016, 08:27 PM
  #59
Supporting Vendor
Thanks,
Actually I really prefer emails.....much easier to access and track and Im notified instantly via my phone.
Guys.....if any of you have questions about my products, want to order something, whatever it may be....while I will get back to all your PM's you will have faster response if you email me at:
mamomotorsports@yahoo.com
Bad Ax.....shoot me an email and I will get you the info you seek and whatever else you might need
Cheers,
Tony
Old 08-26-2016, 03:10 PM
  #60
Silverton
Silverton's Avatar
I know these heads are kick azz but more importantly the package approach I have taken to the design (the right valves, rocker arms, cam lobe profiles, etc.) help guarantee the end user experiences above average results from the install. Getting the combination correct makes the sum of all the parts shine even brighter
-Tony
What valves, springs, guides and rocker arms are you using for your MMS LS7 TFS heads? There is no information on your website. You can PM me if you prefer. - Thank you!
Quick Reply: [Z06] Promising dyno results of my new LS7 heads
