[Z06] Do Weld RT-S 17x5" Fronts fit over Z06 brakes??
Like the title says, I'm trying to get a definitive answer on whether the
RT-S 17x5s 71 Series (5-spoke) will fit over my stock GS brakes without any modification to the calipers.
I've already encountered interference with some 17x12" ZR-1 replicas hitting on the rear calipers, and I'm thinking the front calipers are probably larger, so I don't want to order a new set of fronts and then find out I need to grind down my calipers.
Weld doesn't list a 17x5" version of the 71 series for the Z06 on their website, so I'm wondering if they actually fit??
These are the ones I'm looking at:
http://www.summitracing.com/parts/wld-71hb7050b22a
CI GS (05-27-2016)
Thanks man!
Greatly appreciated. Im thinking I may just order me a set of those and a matching set of M&H skinnies!
I just picked up my 17x11s today. Got them from Hinson, who had them in stock, when everybody else, including Summit, Jegs, etc. had them on backorder. Those guys are the best! Hinson Motorsports - FTW!
What kind of pressure do you need to run in your front skinnies? I ordered a set of 185/55/17 M&Hs but I can't find anything on their website about pressures.
