[Z06] Exhaust NPP Stopped Working
My 2007 Z06 stock exhaust has stopped working from Mile to Wild. I had Corsa's on and wasn't happy so I replied the stock exhaust back on.
However it no longer switches from two to four exhaust.
The mech. is loose and manually moveable but seems to b stuck in the wide open position.
Any idea as to where to start?
Fuse is good!
Fuse is good!
Fuse is good!
Fuse is good!
There is also a module located in the rear bumper cover that has been know to fail in older cars.
There are posts and how-to's for both issues I mentioned.
Fuse is good!
Fuse is good!
Thank you for all of your assistance. I finally got around to working on this issue. Verified the fuse was good, tested the module which is sending 14 volts to the solenoid. Therefore tomorrow I will order a new solenoid.
