A&A or ECS
I'm a little confused... are you saying that when making an order, saying "I'd like the free upgraded head unit" or "I'd like a different smaller pulley" isn't simple?
As for Procharger, could you expand on what makes you think that ease of installation equates to lack of quality? (edit: just note that I'm not saying you're wrong, or anything like that, I'm just curious. I actually went with the A&A kit based primarily on it's price, secondly on the intercooler air dam. But I do have a ProCharger kit on my dad's HEMI, and it's fit and finish is magnificent, just like A&A's kit on my Corvette. I had an Edelbrock on my HEMI before I crashed it.)
I don't like all the pre made rubber parts that come with the procharger and the reason it clears the ABS module is because the shaft and bracket on the head unit is extended. Start overspinning that little p1sc and see if that shaft doesn't bend.
Im going to say it again, they're all good kits.
joemosfet (12-21-2016)
Cool, very valid points. And yeah, we're picking nits here, they're all good kits.
But nits shall be picked, and as for the head unit and desired psi, you can also simply GET the psi you want thru A&A or it's distributor, when you make your order - as I did.
You could simply flip your logic and say that with A&A you get to choose between head units, the smaller more efficient one if you'll never upgrade, or the larger less efficient one if you plan on upgrading. You have to admit that is nice. With ECS, you're stuck with the single larger less efficient head unit and have to use a restrictor plate to lower the PSI.
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,091 Likes
You are not "stuck" with the larger head unit or a restrictor plate. I wouldn't mind selling a kit with the smaller head unit since they are less expensive. We simply found our design makes the most TQ and is the easiest kit to upgrade the power down the line. The larger head unit is far from "less efficient".
Procharger
So there you go. Even the ECS rep says that they'd like to offer multiple head unit options because it gives more flexibility. Score one for A&A.
As for efficiency, the 1200 and Si are 78% efficient while the 1500 and Ti are 74% efficient (maximums), according to compressor maps. Perhaps negligible, but as you mentioned, this whole thread is picking nits. There is the whole issue of potentially reduced longevity that comes with using a restrictor plate, but there are plenty of other threads that fight about that, so I won't get into that.
Ahh I see, you have an agenda. Got it.
The following 3 users liked this post by DOUG @ ECS:
Received 1,195 Likes
St. Jude Donor '15
Why, you make such a compelling argument. He clearly stated he wouldn't mind selling a kit with the smaller head unit. Like I said, picking nits, they're all great. But, lets get back on topic, I didn't mean to cause anybody to turn this thread to ****, just encourage thoughtful dicussion.
Not sure you can go wrong with either. I went A&A. You asked about which is quicker on track and I don't think there's a clear win here either as it depends on how you order it. A&A offered me a larger head unit FOR FREE, but I stayed with the SI which was perfect FOR ME. One thing will remain true = no matter what you get...traction is going to be the biggest issue to track times.
Here is a good thread that compares all of the supercharger options. ECS is on top of all the centri's. This is a base kit comparison. If you're looking for the most power and simplicity ECS is the answer.
https://www.corvetteforum.com/forums...r-sc-kits.html
#33
On thing is the ECS kit is far quieter. Another forum member I took for a ride in my car and he has an A&A kit.
My car its very hard to tell it even has a blower. His had the one thing I hate(but some love) is the rocks in a can blower sound. High pitched and shrill even at idle.
Even listening to some video's ProCharger kits they are pretty loud but they do seem to find more of a home with people who like straight cut gears.
I have a bunch of miles on mine, over 15K, and fill the meth about every 7-8 days which will give you an indication how I drive it. No problems at all.
#34
All great kits, I live close to ECS , so it was a no brainer. Great low end torque and just under 700 rwhp.
Talk to the shops around you, see what they are familiar with and have installed and tuned many of them.
#36
C7 of Year Finalist (performance mods) 2019
#37
Of course it's simple, but my point is with an ECS kit you dont even have to do that. You simply GET the bigger unit and the restrictor plate to go 7-8 or 10 psi. You have to admit that is nice. With any other kit you're buying pulleys.
1) "pre made rubber parts"? really? Not having to cut the skid plates and intake tubes is awesome! Can't mess it up. Also, another member on here took advantage of that and was able to return his car completely to stock without having to buy new parts to the replace the ones he modified. I don't ever plan on doing that but that's a good option to have.
2) Many of the highest hp and fastest C7s are running prochargers F1 series with that exact bracket and untouched abs modules:
Moving the abs module is not incredibly hard, Procharger just designed their bracket a such way where its not needed. A&A and ECS decided it's a simple enough procedure and focused their efforts elsewhere.
I picked the procharger because:
-the simplest kit to install yourself and requires zero cutting. Even if by a tiny margin, it's still simpler.
-comes with a mail tune (got it dyno tuned 2 weeks after)
-I liked the bigger intercooler because I like to take my car to the track and its hot as hell here in texas.
-I like the way the bottom of the intercooler has protection with louvres
I didn't pick ecs because:
-cutting
-having to get car to tuner right away
-bottom of the car setup with all the rubber flaps
-no mail tune
I didn't pick A&A because:
-I think the mail tune was the only deciding factor, i was very close to getting A&A
All 3 kits will work 90% the same. The last 10% is: one might have lower IATs in hotter climates, the other will have more torque below 4500 rpm, the third may have a quieter unit. There are an absurd amount of threads already asking the same question.
I must say that I wish procharger worked like the other two smaller companies in such that the guys at ECS and A&A will answer the phone on the weekend and do everything to help you. I also must say my procharger tensioner was seized up and needed to be lubed. Otherwise it runs like a dream, zero problems. Also zero oil in my catch can/breather after 3k miles which makes me wonder why I spent $500 on that stupid thing.
Anyways, helical gears, p1sc, not loud enough to be annoying but loud enough to tell you this thing is not stock.
and you can hear the whistle and woosh here. To put into perspective how track friendly this kit is, my transmission and water temps gave me warnings before IATs got too high.
blown81bu (12-23-2016)
#39
Say it again Procharger!
The above statement i totally agree
No cuttting or modifying anything especially an auto
10.3@140
10.3@140
#40
10.3@140
https://youtu.be/s6tlxXX7__E
10.3@140
