C7 Weight Issues
Old 02-01-2013, 03:02 AM
  #141
texel
texel's Avatar
Nope they just put their test cars on a scale.....
Cheers
Old 02-01-2013, 01:26 PM
  #142
stevebz06
stevebz06's Avatar
Originally Posted by Torch Z
Oh boy have you just reopened a can of worms. I'd love to see an analysis showing exactly what items, and how many lbs. for each, offset the 200lbs lower starting point in your C4 PLUS the lighter aluminum frame, engine block and heads, CF body panels, no spare and jack, etc. We can surmise it is airbags all over the place, passenger compartment reinforcements in doors and A-pillars, extra sound insulation, interior coverings, steel torque tube, much bigger brakes, and other items. Problem is, we're all conjecturing and nobody really knows except the C7 team.
The comparison would be very interesting. I hold to the belief that GM could have made a great Vette sticking to a no-compromise "it will be less than 3K lbs" mandate even given the safety and usable space requirements. But, they had their reasons not to...and they are smart people.
I'm in the habit of weighing everything in my car when I remove it. I happened to have both seats out of my 86 one day and compared the weights: the electric driver's seat was 15# heavier than the manual passenger seat. That's just the seat, then you add the wiring and relays and switches. You're looking at at least a half percent of the vehicle empty weight. Multiply that by probably a dozen other systems on the C7, and you end up heavier than desired.
Old 02-01-2013, 03:36 PM
  #143
Rapid Fred
Support Corvetteforum!
Rapid Fred's Avatar
Received 1,314 Likes on 754 Posts
Cheers
I thinky you may have missed my point. R&T also had the new Carerra S on the scales with driver, and it was 85 lbs less!
Old 02-01-2013, 03:55 PM
  #144
Rapid Fred
Rapid Fred's Avatar
Great info/insights. This is the analysis I'd like to see. What could have be axed without compromising the mission of reasonably comfortable sports GT suitable for daily-driver duty? I never found having electric-everything seats, heavily-padded interior panels, 3 overdrive gears, or more than 4 speakers necessary to fulfill that mission.
Old 02-01-2013, 04:23 PM
  #145
Kappa
Kappa's Avatar
Looks like there's a lot of variability. I still think MT and C/D weigh there cars on full without driver unless stated otherwise.
Old 02-01-2013, 04:32 PM
  #146
rcallen484
rcallen484's Avatar
Drivers' weights can vary by 150 lbs EASILY (100 lb woman or jockey vs. 300 lb 6'2" powerlifter. Those that include driver could be meaningfully affected by that variable.
Old 02-01-2013, 04:34 PM
  #147
Kappa
Kappa's Avatar
I know, that why R&T is the only one that breaks that down. If they don't give the driver's weight, I assume that there wasn't a driver in there.
Like I said, the curb weights of American cars are always spot on in these magazines.
Quick Reply: C7 Weight Issues
