Sae hp
Old 05-17-2013, 10:04 AM
bigwoolyg
bigwoolyg's Avatar
Originally Posted by AORoads
when I read about 7K rpm vs. 6600 rpm, I begin to wonder about engine life. especially as it relates to getting more than 100K miles out of it (since dropping dead at 100.1K miles wouldn't put a smile on anyone's face) and that pesky thing called a "warranty from GM on the powertrain."
I Wonder what % of vettes actually make it to 100K miles in their lifetimes.
Old 05-17-2013, 10:05 AM
vetteLT193
Support Corvetteforum!
vetteLT193's Avatar
Originally Posted by sam90lx
Thats was I was saying in another thread but was labled a hater by some ***!
Red line is almost never right at peak HP. It is set just a bit above it so you can rev through peak power to make use of all of it AND get right back into it after shifting. If you set the redline at peak HP then you would end up dropping far below peak power after shifting.
If this chart is real then it's going to be a higher than 6600 rpm red line. 7000 or possibly higher.
Old 05-17-2013, 10:08 AM
CPhelps
CPhelps's Avatar
That's the same graph that was in the SAE paper discussed a while ago. My thinking is that it is from before the certified testing since it was on the paper written about the design. Additionally all the graphs I've seen from SAE certification have the SAE certified logo. It is likely that the testing produced similar numbers though, so I expect the final numbers to be very close to this.
travisnd
travisnd's Avatar
Some of you guys clearly don't road race or drag race much. You don't want to shift at peak power. You want to shift after peak to maximize area under the curve. For road racing having additional RPM range allows you to extend a gear and not waste time shifting. There are cases where we'd rather let the car bang the limiter at the end of a straight vs. making a shift.
My guess is the 6500 is all marketing misinformation... The car will have 465 horse with a 7000 rpm redline and a massive torque curve.
Remember... the tachometer is electronic... they can make it say 12,000 if they want.
Old 05-17-2013, 10:15 AM
sam90lx
sam90lx's Avatar
Sure I understand that but some I believe thought peak power was going to be made at 7k+
Old 05-17-2013, 10:34 AM
RocketGuy3
RocketGuy3's Avatar
465 would be disappointing, but I'll wait until we get final performance figures before I pass judgment. I really hope the 475 rumor with 7100-RPM redline is true... Yes, 10 hp isn't much, but your hopes have to lie somewhere, heh.
Old 05-17-2013, 10:37 AM
Davidl81
Davidl81's Avatar
What if it is 465 base, then 475 with NPP? Just a thought as the NPP has 24% more air floe than the C6 NPP.
Old 05-17-2013, 10:38 AM
Process Black
Process Black's Avatar
Granted most people don't use their cars as daily drivers, but I've put over 100k on each Corvette I've owned and their engines feel as potent as they were with 5 miles on the clock. This includes plenty of high speed driving/track use.
Regular maintenance is key.
Old 05-17-2013, 10:58 AM
RocketGuy3
RocketGuy3's Avatar
Better, but I was hoping for 480+ with NPP. It just seems like with this significant improvement in tech (higher compression ratio, DI, higher revs), they should be capable of at least a modest 10% improvement.
Old 05-17-2013, 11:20 AM
OHV4LIFE
OHV4LIFE's Avatar
My guess is that the real target is 465 hp. The LT1 weighs 465 lbs. A 465 hp output would put it at the 1 hp/lb power to weight threshold, which is a significant achievement.
Old 05-17-2013, 11:32 AM
Kappa
Kappa's Avatar
Agreed. It slots the LT1 right between the LS3 and LS7 and is more than enough to take on cars like the 991 Carrera S, Cayman S, or whatever else is in the $55-90K class.
I guessed 475hp and I think it'll get close.
Old 05-17-2013, 12:06 PM
Snorman
Scraping the splitter.
Snorman's Avatar
Received 1,028 Likes on 486 Posts
St. Jude Donor '13-'14-'15
Originally Posted by Kappa
...and is more than enough to take on cars like the 991 Carrera S, Cayman S, or whatever else is in the $55-90K class.
Now that you've mentioned Porsche, it's a matter of time before our magazine quoting trolls blow up this thread.
You know those clowns do a keyword search everyday to determine in which threads they are going to sh*t.
S.
Old 05-17-2013, 01:31 PM
  #33
CaryKen
CaryKen's Avatar
Can't quote you any studies or surveys, just another personal anecdotal data point.
My 2000 C5 FRC now has 108,000 miles. Running absolutely great.
Old 05-17-2013, 02:04 PM
  #34
Jawnathin
Jawnathin's Avatar
Originally Posted by Trackaholic
Or maybe it doesn't really get to 7000 except under laboratory testing.
-T
My gut feeling tells me that that is the case. While it may have spun upto and run to 7k for testing purposes, it doesn't mean GM is comfortable with production motors spinning that high. There might have been concerned about long term durability and subsequent warranty costs.
I just read an article the other day about LS7 development and touched on the amount of effort it took for GM to get the LS7 to 7k RPM. The LT1 does have a shorter stroke and smaller pistons, so it could be a bit easier, but it did take considerable effort, including using expensive titanium connecting rods to get it to spin so quickly.
FWIW, piston speeds on an LS7 are 4700 feet per minute, almost 20% greater compared to the 4000 feet per minute for the LS3, and I assume the LT1.
Given GM already announced the specifications, I am expecting 6600rpm but would be excited to see anything above that.
Old 05-17-2013, 02:34 PM
  #35
travisnd
travisnd's Avatar
The LS7 needed special stuff because the long stroke made for high piston speeds. LT1 has a shorter stroke.
Old 05-17-2013, 03:39 PM
  #36
99C5JA1
99C5JA1's Avatar
If increasing HP was their only goal you would easily see more. The Fed's and the increasing standards have a strong influence on the design goals. We can both dislike that (I know I do), but that doesn't change it.
Old 05-17-2013, 04:47 PM
  #37
sam90lx
sam90lx's Avatar
So are these numbers accurate or not? 465 and 448?
To Sae hp
Old 05-17-2013, 04:58 PM
  #38
Hemi Dave
Hemi Dave's Avatar
That's when you are in econo mode
........in track mode its 505HP and 505TQ
Old 05-17-2013, 05:00 PM
  #39
rad928music
rad928music's Avatar
100k Miles is nothing for a small block chevy.
Even the old ones.
Old 05-17-2013, 05:04 PM
  #40
bigterpsfan
bigterpsfan's Avatar
They said 450 so consider even 451 a bonus.
Quick Reply: Sae hp
