Terrific development article from Corvette Mag
Old 06-19-2013, 05:12 PM
BuckyThreadkiller
Successful Plumber
Support Corvetteforum!
BuckyThreadkiller's Avatar
Location: Top of the hill, 3rd mailbox on the right. Texas
CF NCM Ambassador
CI 6-7-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10
NCM Member '09
Default Terrific development article from Corvette Mag
Great Piece -
http://www.corvette-mag.com/issues/8...s#.UcIdKRYaGsS
Behind the Scenes
We take an insider’s look at the development of the 2014 Corvette Stingray, from the building of early prototypes to the testing of production-ready vehicles.
By Eric GustafsonJune 14, 2013
Josh Holder has a highly demanding job. As Corvette Program Engineering Manager, he has overseen the development of the 2014 Corvette Stingray, an enormously complicated, three-year process fraught with design challenges, logistical hurdles and management demands. It was Holder’s responsibility to make sure the program stayed on schedule, from the creation of early proof-of-concept cars to the design of buildable prototypes to the testing of production-spec vehicles. Along the way, Holder had to make sure the engineering team was coordinating its work with the folks at the Bowling Green Assembly Plant—the C7 had to be better, but it also had to be buildable. Oh, and there was the maze of Federal safety and emissions tests that needed to be negotiated. In early April, as the C7 testing program was coming to an end, Holder walked us through the development process.
It starts with mules. In the fourth quarter of 2010, Chevrolet began building vehicles used to test the fundamental engineering concepts behind the C7. Referred to as “mules,” these hand-built cars helped engineers and designers make important decisions about the new Corvette’s structure, powertrain and styling. It was at this point, for example, that big changes such as the C7’s new radiator layout were examined for their viability.
The first seven mules were non-runners, used mostly for safety testing and dimensional analysis. By early 2011, the Corvette team had built running vehicles using the current Corvette as a platform. Holder pointed out that getting these cars on the road was a real feat because they combined both C6 and C7 elements. Since the C6 is outdated electronically, the mules required two electrical systems: one for the C6 part of the cars and another to run the new C7 elements. In all, 19 mules were built.
By late 2011, with most of the big decisions about the C7’s design having been worked out, the Corvette team was ready to begin building what are referred to as Integration Vehicles. Though highly representative of the final product, these test cars were mostly hand-built and, as a result, extremely expensive to produce. According to Holder, the construction of the IVers—as they are called—was the development program’s biggest expense. Over the course of C7 development, a total of 86 were built. “We had to fight to get those 86 cars,” said Holder of budgetary battle with those controlling the purse strings.
Initially, an IVer’s purpose is to help the engineers work out the assembly processes for the new Corvette. Their aluminum frames were built in the Detroit area by the same the robots that now reside in Bowling Green. The subcontractors who designed, built and programmed the robots were on site, right alongside the Chevrolet engineers. During the assembly of the rest of the car, engineers had to not only make sure all pieces fit together properly, they had to determine precisely how the car should be put together. Not surprisingly, representatives from Bowling Green were deeply involved in this process. Once established, build protocols were tested on a mocked-up assembly line, also located in the Detroit area.
Once built, IVers were quickly pressed into their various testing duties, that is after they had received several layers of camouflage. Some cars, especially early ones, were built with specific tests in mind. For example, IVers destined for chassis development might not be built with complete instrument-panel assemblies. However, all IVers eventually served multiple purposes, with a good number of them ending up crumpled in the name of occupant safety. Holder says that 95 percent of 2014 Corvette testing was completed using the IV fleet.
Given the advanced state of computer-aided design and the sophistication of modern simulation devices, we asked Holder if the C7 required less real-world testing than previous Corvette generations. A 15-year GM veteran who worked on the previous two Corvettes, Holder says the C7 underwent the same amount of physical hardware testing as its C5 and C6 predecessors. “Cars have gotten more complex, which requires more testing and analysis,” he explained. The difference, he says, is that the predictive tools take a lot of trial and error out of the process, leading to better results. This is especially true with aerodynamics, where the use of computational fluid dynamics has made airflow management less of a black art. Still, the C7 spent over 700 hours in the wind tunnel, and there is no substitute for having a living, breathing test driver check for potential issues like wind noise.
The same is true of testing subjective aspects of the driving experience like ride quality; here, the human element is key. The IVer fleet pounded plenty of pavement—no less than 1.5 million miles, to be exact. That’s 60 times around the globe. At General Motor’s expansive Milford Proving Ground outside of Detroit, at Michelin’s Laurens Proving Grounds in South Carolina and at racetracks across the country, C7 prototypes were subjected to myriad forms of abuse. Previous tests were verified, build quality was validated, durability was proven and performance boundaries were pushed. Though IVers were exposed to temperature and weather extremes in GM’s full-size simulators—from minus 40-degree F temperatures to monsoon rain—that didn’t keep test drivers from conducting real-world tests in harsh conditions.
At the end of March 2013, just before we spoke with Holder, the C7 development program reached a major milestone: “vehicle testing complete.” We asked if final tweaks could still be made on such things as the computer algorithm that controls the Magnetic Ride Control shocks. Holder replied, “The tune is done on the 2014 Corvette. We have to put a stop to it at some point.” He acknowledged that some minor changes could be made, but only if there was a problem that needed to be addressed. At that point, the focus of the development program had already shifted to validating the build process at Bowling Green.
In April, 21 Production and Process Verification vehicles were built. This was followed by the building of a small batch (or “bucket,” in company jargon) of Stingrays that were to be used for Federal safety and fuel-economy testing. After that, Holder said 300 “saleable” C7s would be built for GM’s own captive test fleet. These cars will be driven by a wide variety of GM employees, with the aim of checking build quality and tracking down any potential problems before final production begins sometime late this summer. Until then, Bowling Green will be focused on perfecting its assembly techniques and progressively ramping up line speed.
We can’t wait to get behind the wheel of a 2014 Corvette Stingray in August. Thanks to the exhaustive work of its development team, and the stewardship of folks like Josh Holder, it promises to be an extraordinary vehicle.
Old 06-19-2013, 05:57 PM
BlueOx
BlueOx's Avatar
Originally Posted by BuckyThreadkiller
Dupe...but yes it is a great piece with great pics!
http://forums.corvetteforum.com/c7-g...s-article.html
Old 06-19-2013, 05:59 PM
rcallen484
rcallen484's Avatar
Anyone want to suggest another word for outdated?
"Since the C6 is outdated electronically, the mules required two electrical systems: one for the C6 part of the cars and another to run the new C7 elements. In all, 19 mules were built."
Old 06-19-2013, 06:00 PM
BlueOx
BlueOx's Avatar
I was going out of my way to NOT say it!
To Terrific development article from Corvette Mag
Quick Reply: Terrific development article from Corvette Mag
