C7 vs C6 dyno comparison
I scaled and overlayed my 2009 C6 LS3 dyno graph that was done at Superchips over the C7 one shown today by Lingenfelter. My car was stock with the NPP at the time of the dyno run using 93 octane.
Dyno comparisons across vehicles are never scientific but it's a rough idea for comparison.
The torque graph shows the C7 above the C6 all the way,
BUT
the HP graph shows the C7 under the C6 until 65 MPH,
Thus somebody screwed up one of the axes; it can't work that way.
HP[rpm] = TQ[rpm]*rpm/5252
BUT
Agreed. If the torque graph is right though, that's a pretty nice improvement.
Like I said it's an overlay, they're not graphed in the same software. I used Paint.net to scale and layer. Also dyno runs are not 100% anyways.
Received 2,276 Likes
C4 of Year Winner (performance mods) 2019
Here's one from my stock 2013 GS that is scaled to match:
I did the C6 in red, but it's still not the easiest to make out. The upper end is very similar, but the C7 has a big TQ/HP bump down low.
very nice comparison ...now I would like to see the Lingenfelter LS3 525 package dyno sheet on their site versus the C7...and the 525 package does not use an upgraded exhaust manifold such as the LS7/ZR1 or new C7.
The C7 power increase over the C6 is minimal. Although the weight increase in the C7 is substantial when compared to a base C6. I am a corvette lover and I really like the C7, but the power could have been better.
Yeah I realized after I did it. That one's easy though, the C6 is the lower of the two. I also did one vs my C6 with just Z06 exhaust manifolds & H-pipe (stock tune & filter):
I would recommend taking your charts down since they will just confuse people.
Scraping the splitter.
You are comparing STD correction to SAE correction. This is not a valid comaprison. STD correction is always going to give you much higher numbers than SAE. You peak stock 401 hp STD = 382 hp SAE and your modded 414 hp STD = 395 hp SAE. You would see a much bigger difference in the graphs if you were comaparing apples to apples.
I 'thought' the difference when corrected to STD was about 2.6%, but either way, the LS3 is not making close to the same power as the LT1 stock vs. stock. Lingenfelter posted overlays of an LT1, LS3 and LS7 here...
http://forums.corvetteforum.com/1584989050-post54.html
Scaled the same, same smoothing, all SAE.
S.
Good catch.
S.
S.
Stupid Dynojet software (I had it at SAE, not sure why it changed) I'll reset it to SAE and repost later.
Leveling to SAE won't make a ton of difference here. The numbers on the first graph are right where they should be for the respective engines. Peak power of 388 for the LS3 and 416 for the LT1.
S.
LT1 > LS3 by 31.1HP at peak
But you are right... if you look at the torque increase of the LT1 across the RPM range and the extra area under the HP curve vs. the LS3, the differences are meaningful... very meaningful. What impresses me most is the LS7 and LT1 graphs to 5,000RPM... effectively identical. After 5,000RPM, the LS7 walks away (and it weighs less) but until then, the LT1 is impressive!!
LS7 > LT1 by 36.6HP at peak
S.
Fixed the graphs, the original links are now the updated with BOTH showing SAE.
