Front Air Dam
SUPPORT AUTISM
Try to figure this one out.
Z51 is missing the center piece which is designed to work in conjunction with the rear spoiler.
Base has the corner pieces and the middle piece
Base with the optional installed Z51 spoiler has the corner pieces and the middle piece.
Does this mean that the rear spoiler is unsafe in the non Z51
or that there is no reason to delete the center piece in the Z51
Hope this helped.
Hope this helped.
Received 9,518 Likes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
I didn't put the center piece back on mine when I got it back from the factory. If the Z51 runs cooler without it, I figured my non-Z51 would run cooler without it too.
I took off all three of them on my car too. Im not a racer and find it hard to believe that there are that many people this concerned about the heat build up due to the part missing. In my case I did it as my driveway is steep and it rubs pretty bad. I'm also hoping that some items on the road will now clear without hitting that piece. It does look a lot cleaner in the front with out it.
