Expected Tire Life?
Expected Tire Life?
OK, so I just replaced my tires at 18,000 miles. I probably could have gotten about 2000 more miles if I hadn't tracked the car last weekend. Got back from the track, and most of the tread on the outside of the front tires was gone.
I've replaced them with the non-run flat tires (a little cheaper, and they are supposed to be slightly stickier according to the Discount Tire guy I talked to.
Now, I just need to research what wheels/tires I should get strictly to run at the track.
Yet the base will do 1g and for a non track suspension that unbelievable .My base 7 speed rides and is as quiet as the Infinity I replaced with the Stingray .
Yet the base will corner at 1g added to that my base 7 speed rides and is quiet as the Infinity I replaced with the stingray . I was pleasantly surprised as I wanted the Z06 and when I found out I would have to wait till 2015 I figured why spend more to get the 2014 Z51 when I will replace it with a Z06 in 2015 ? I was very impressed and surprised with the base .
Unless you spin the rears a lot on take-off, it seems the fronts would need changing more often. My fronts are always worse than my rears and I assumed it was because it was much heavier up there (and though I don't track my car, I DO drive it with spirit--my wife hates to ride with me).
On my wife's Cooper S, she neglected to have the tires rotated and consequently, her fronts wore out and had to be replaced--rears were still good for some time. And she DOESN'T drive spiritedly.
Kind of surprised by this...
And the mini is FWD is it not?
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
If you're not tracking the car, one idea is to have the front realigned to the more neutral end of the camber alignment and that will help quite a bit.
