Sirius XM 2014 Vert Vet erratic operation
Old 09-29-2014, 04:34 AM
Cape Schrod
Cape Schrod's Avatar
Default Sirius XM 2014 Vert Vet erratic operation
XM radio on, enter garage with radio on. Turn off ignition and exit. Come out later in the day and exit garage radio still in on position and no XM sound on any channel. Have to stop and turn car off and restart car to get radio to operate. Any ideas?
Old 09-29-2014, 09:24 AM
aj98
aj98's Avatar
My guess would be the structure of the house blocking the signal. I get that when I pull into my driveway b/c of the trees around my house.
Mine takes about 30 seconds for the radio to reacquire signal after backing out and clearing the treeline.
Old 09-29-2014, 10:22 AM
runutzzzzz
Support Corvetteforum!
runutzzzzz's Avatar
Your car has a buffer built in. It's possible that when you pull in you're playing on the buffer and you turn the car off before the buffer runs out.
Next time you pull in, sit in your car for 30 extra seconds and see if the radio cuts off.
Old 09-30-2014, 09:42 AM
Cape Schrod
Default XM issue
Thanks for your reply. It still does not reacquire when I am miles from the house. Only reacquires when I stop and shut off the car and re-start. One other person mentioned a buffer which could be the issue.
Old 09-30-2014, 09:45 AM
Cape Schrod
Default Buffer
Thanks. I will try it and let you know. Never had the issue with my previous Corvette's and other GM cars.
Old 09-30-2014, 10:53 AM
runutzzzzz
runutzzzzz's Avatar
All depends on placement of the antenna in the car. The C7 I think has the antenna in the front fender? I could be wrong but that's what I was told when they replaced my antenna.
I think the C6 had them in the mirrors.
To Sirius XM 2014 Vert Vet erratic operation
Quick Reply: Sirius XM 2014 Vert Vet erratic operation
