Tilt down mirror problem
Anyone else experience this? I have only the right mirror tilting down when in reverse but after backing up about 25' the mirror goes back to its regular position even though I'm still in reverse and backing up. Shouldn't it stay tilted down until I shift out of reverse? I have a M7.
I didn't know it behaves this way. Do you use both of your memory positions? Maybe you can program one of them with the mirror positioned the way you want it.
Or just back up a lot faster. (Assuming it's a time out, not based on distance.)
Received 1,984 Likes
BUT I leave the mirror control in the right side position and occasionally tilt the mirror manually. Leave it that way and when I start it up it returns to the "full" position.......problem solved.
