Z51 Sway Bar Part Numbers?
I was going to buy the Z51 Sway Bar package from Gene but it appears he is in transition mode so... Anyone have the part numbers for all the parts you need to install the Z51 front and rear sway bars on a base model, including the 4 bolts that cannot be reused? Thanks!
I don't have numbers but you might try a new vendor here. Haven't seen them in C7 but here's a post from C6:
https://www.corvetteforum.com/forums...ettes-com.html
Platinum Supporting Dealership
Front Bar: 20966781
Rear Bar: 22936508
Front Bracket: 20959448
Rear Bracket: 20959449
Front Bushing: 22950838
Rear Bushing: 22950835
Stabilizer Bar Links: 22945601
I don't have the PN for the bolts, should be the same Z51 or Base, Front or Rear.
Rear Bar: 22936508
quantity
I am guessing 2 brackets needed for each bar and 2 bushings each?? What about the links??? Nate... you ever thought about putting package together for us to purchase?? Thanks Andrew
rear bar
You forgot: clamp(2)20959449, Bolts(4)11588742, nuts(4)11516078. nuts and bolts are special. They are tapered,start getting tight before they are snug.
for what it is worth I had/have an order in with GMPartshouse , which as we know are no more. I called Patriot Buick GMC and spoke to Joe Lee, he is left with the unfortunate job of untagling the separation and he has pledged the best prices and even better services to get the forums business give him a call and tell him Barry sent you
order?
Tell him that Barry sent you promised to take good care in the future.
For what it is worth he seemed very apoligetic about the situation and seemed to take full responsibility, while not bad mouthing Gene and Pat once. He was supposed to look over my order and call back Friday, did not get that call but want tobe fair. More to follow
Finally if Glenn E runs across thishe can tell you more than you want to hear I am sure.......good luck
Last edited by Zymurgy; 10-04-2014 at 06:50 PM. Reason: You cannot post contact info for non-supporting vendors
Received 1,293 Likes
Unmodified C8 of the Year 2021 Finalist
2018 C7 of Year Finalist
Good pic here in Modshacks Thread, post 1. Only missing 4 new bolts for the front reinstall of the new sway bar.
https://www.corvetteforum.com/forums...a-base-c7.html
I finally got this covered and ordered. Thanks for the suggestions and help. I will try and remember to write down all the part numbers with quantities and post them here for future reference.
