High (to me) temps.
High (to me) temps.
My 14 NRB cpe, a6 runs at a consistent 220 degrees (water) and 200 degrees (oil) in 65 degree ambient outside temp.
This seems too hot to me, I have to run a frt plate, so I modified the aero panel to accept the plate with a smoked cover.
I suspect, and have removed the panel and plate to detail the temp changes.
I would rather not run the plate than change out the t-stat to a 160/170.
Frt plate be damned.
Received 3,291 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
They wont believe but here goes. It has to do with emissions, prolonged engine life and computer programming.
Lowest emissions at that heat range for acids in oil, moisture in crankase and CO2 emissions etc,
metal parts fully heat soaked expand to their correct sizes for bearing clearances and piston bore clearances resulting in minimal piston skirt and block bore wear for one thing and
finally the engine computer is programmed to run the engine richer at lower engine temps so simply installing a 160* or 180* thermostat may even trigger a CEL with engine in perpetual (closed loop) not at operating temp mode,,,as I understand and I am sure there are many more reasons not mentionied which I hope others will add.
E-Ray, 3LZ, ZER, LIFT
Received 9,662 Likes
Had a Hypertech program in my S10 and used a 160 thermostat as they suggested along with the high test gas level tune. In the winter where it ran at 160 it tripped codes frequently and I had to reset them about once a month. On that iron block and heads V6 it did help throttle response significantly. Would not consider it for my C7 for the reasons you state.
You want your oil to get hot enough to boil off the water that condenses in it. 220 isn't high at all for coolant temp. If it didn't get above the boiling point (212F) we wouldn't need pressurized cooling systems.
As far as the thermostat, understand that sets the minimum operating temp for a fully warmed engine, not the maximum. If your engine runs at 220F with a 190 degree thermostat, it's not going to suddenly start running cooler with a 160 degree thermostat. Both 'stats are fully open at 220F. A cooler thermostat just means it will open faster, and your engine will take longer to get to normal operating temps. Not that those normal temps will be lower.
Looks like 220 on the analog gauge, but that is just the way the gauge is configured. Using the digital gauges mine runs at 204 for both coolant and oil when cruising.
Received 2,486 Likes
St. Jude Donor '15
"In honor of jpee"
Sometimes, you have to read where the folks are really pushing their cars, and have them prepped somewhat to do so. I'd specifically read posts #32, 35 of RichieRichZ06 and #101 of Anthony@LGM who sez: "FYI...our endruance cars run 180-210 most of the time. In traffic or something like that you might see small periods of time in the 220-230 range but not for long.
The sprint setups, or in qualifying trim you might run 230-240 for a few laps with the grill taped but again that is for a qualifying setup not in race trim.
240-260 water temps on a production car is just stupid. "
from this thread: https://www.corvetteforum.com/forums...lant-temp.html
I am one of those idiots who is running a Lingenfelter 160 deg Thermostat. I have yet to see a cel in a couple months of mostly in town driving here in Naples. My water temps are ALWAYS in the 165-171 deg temp range ( on my DashHawk), unless I do a WOT run to say 80+ and even then, the temps are back to the lower range within 30 seconds. My oil temp when car is fully warmed up is 175 deg ( gauge by speedo). For comparison, a 160 deg Tstat in both of my G8 GT's gets me about a 15 deg drop to around 180 in similar summer conditions. However, my IAT (Intake Air Temps) are a minimum of 6 degrees above Ambient, and the Vette really seems to heat sink the CAI and intake manifold. Goes to 30 deg above ambient sitting at a long stoplight. My G8's are just the opposite. While they do heat sink, the IAT temp comes back down quickly to within a couple degrees of ambient, even at speeds as low as 40 mph.
While my 15' Z51 will see some cool/cold temps when I take it back to Iowa from 5-15 thru 10-15, it will be interesting to see if I get codes. Never have had a code on any other vehicle (many) with lower temp T-stat.
High engine temps are from what I understand desired by MFG for emissions, and no real other reason.
